Author Topic: Z Bar removal tips ?  (Read 1450 times)
Offline Racer57
« on: April 13, 2015 - 05:49:08 PM »
70 cuda 383 Tremec T500
Bushings are shot and have new otw from Roseville. Been looking it over.  Whats the easiest way to remove the Zbar/torque shaft ?
Once I have the linkage and the spring clip removed will it slide to one side allowing removal ?  Also,  I thought about grease zerks. I would make a wooden dowel cut to length for the middle 3rd of the tube to take up some of the space with a small screw to hold it and then a have a grease zerk near each end. Is it worth the hassle ? I can do it easily.
Been telling my wife that this job is gonna make my 4post lift worth every dime !!  :D
Offline CudamanTom
Re: Z Bar removal tips ?
« Reply #1 on: April 13, 2015 - 08:23:48 PM »
I would loosen the bolt on the Z-bar bracket mounted to the frame and take the Z-bar/pivot bolt out together. This will make life easier when putting it back in with it already in the Z-bar. Yes, the Z-bar will slide out with the spring clip removed from the bellcrank side attachment pivot bolt.
I don't think grease zerks are needed if the seals have held up but if it's easy enough to do, then I don't see a problems.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #2 on: April 14, 2015 - 09:23:41 AM »
That's how I did mine.
Offline Racer57
« Reply #3 on: April 17, 2015 - 10:22:49 PM »
Thanks for the tips. I had everything done in about an hour. :D
Offline CudamanTom
« Reply #4 on: April 17, 2015 - 11:05:06 PM »
Good to hear.  :2thumbs:
« Reply #5 on: April 18, 2015 - 03:09:57 PM »
Somebody did something that only took an hour!?!  :clapping:
Offline roadman5312
« Reply #6 on: April 18, 2015 - 03:25:01 PM »
                   Last " about an hour " job I did started @ 9 am, finished it up about noon.   :walkaway:
