Author Topic: Carb rebuild advice!  (Read 10239 times)
Re: Carb rebuild advice!
« Reply #15 on: April 20, 2015 - 04:24:21 PM »
You can torque the base bolts but I never have just snug them up .
 the choke spring is bi = metallic so it will tighten cold & uncoil as it heats , just leave it alone & line up the drive pin with the loop @ the end of the coil .
 the blue gaskets are not re-usable & stick the same as the older ones but for a few days you should be able to get them apart before they seal up & stick .
Offline Tonker1
« Reply #16 on: April 20, 2015 - 07:59:34 PM »
Simply lining up to the two components is much easier than trying to work out a way to tighten the spring while mating the black cap to the carb!
Will finish the carb off today and start tuning Friday after work!
Thanks to everyone for all the advice so far! (The 'so far' leaves space for difficulties with tuning!)
Offline Tonker1
« Reply #17 on: April 21, 2015 - 07:24:18 PM »
« Reply #18 on: April 21, 2015 - 08:27:12 PM »
Looking Good  :2thumbs:
 We will see how she runs now
Offline 734406pk
  • Andy
« Reply #19 on: April 21, 2015 - 08:30:50 PM »
Beautiful job! Looks great!  :thumbsup:
Offline cudabob496
« Reply #20 on: April 21, 2015 - 08:32:13 PM »
2011 Kawasaki Z1000
Offline Tonker1
« Reply #21 on: April 22, 2015 - 03:32:16 AM »
I really appreciate the comments, thank you!
Before the rebuild, the carb had quite a few leaks which I suspect were effecting the internal fuel/air circuits. The exhaust was always blue and there was bogging when going to wide open throttle regardless of how fuel mixture screws and float heights were set, should note the jets are appropriately sized. With the carb now rebuilt the plan is to do a base tune by checking engine behavior under certain loading. Then once I've had a bit more time with the tig, I'll weld in the bung for an afr gauge that I have, and really get into the finer points of tuning!
Top picture a Nitrous explosion??
Nitrous explosion would be both good and bad, bad for the obvious reasons, but good because I would have a complete NOS set up!
Offline Tonker1
« Reply #22 on: April 25, 2015 - 09:13:05 PM »
It lives! Bonus, there are no petrol leaks!
13 inches of vacuum at 600-800rpm. Overall I would say that is a great success, just have to get the afr bung now!
Thank you for all the help and advice!
Offline 734406pk
  • Andy
« Reply #23 on: April 25, 2015 - 09:15:55 PM »
Excellent job sir! If you have any tuning questions, just post.  :thumbsup:
Offline cudabob496
« Reply #24 on: April 25, 2015 - 09:21:00 PM »
there's a bolt on bung that you do not have to weld
2011 Kawasaki Z1000
Offline Tonker1
« Reply #25 on: April 25, 2015 - 10:32:31 PM »
Thank you, I appreciate that!
This is the lowest stable idle then engine has ever been at, the miracles of a leak free carb!
Offline cudabob496
« Reply #26 on: April 26, 2015 - 12:47:29 AM »
low idle isn't always that great. It means your water pump and alternator are turning slow, and may
not do the jobs they do as effectively.  My Cuda idles at 1000 rpm.
2011 Kawasaki Z1000
Offline Aracer
« Reply #27 on: April 27, 2015 - 10:55:24 PM »
Don't forget to use pin drills, the correct size to clean all top air bleeds, probably .070 for idle and .035 high speed bleeds, also clean idle feed restrictions and emulsion holes in the metering blocks. While your in there open the emulsion holes up to .033. in order to compensate for today's pump fuels.
