Author Topic: 1/4" wheel spacer  (Read 1969 times)
Offline RCCDrew
1/4" wheel spacer
« on: April 15, 2015 - 09:15:36 AM »
I just installed a 66 B Body rear and Dr. Diff relocation kit. My wheels are now too close to the leaf springs. If I use a 1/4" spacer behind the wheel will I need longer wheel studs? I am running alloy wheels.
Re: 1/4" wheel spacer
« Reply #1 on: April 15, 2015 - 12:35:13 PM »
General rule with steel threads is 1.5 times the diameter engagement, I like 2x ( 1/2 thread = 1" engagement) .
 I'd suggest a quality spacer NOT cast aluminum!
« Reply #2 on: April 15, 2015 - 01:07:40 PM »
How close is the tire to the spring?  What is a safe minimum distance?  Most of the tire flex should be below the spring shouldn't it?  I guess it depends on wheel width, tire size, section width and aspect ratio.  A higher aspect ratio will flex more.
Offline RCCDrew
1/4" wheel spacer
« Reply #3 on: April 15, 2015 - 03:06:45 PM »
It works right now. It's about 1/4" from the spring. I want to put wider tires on though and that will put the tire into the spring. Right now I am running a 275 40 17.  I believe I can run a 295 or 305 with the new setup.
« Last Edit: April 15, 2015 - 03:09:12 PM by RCCDrew »
Offline crash340
« Reply #4 on: April 15, 2015 - 03:37:21 PM »
what is the rim width and back space?
Greg
73 Cuda
Brisbane, Australia
Offline RCCDrew
« Reply #5 on: April 15, 2015 - 09:08:23 PM »
« Reply #6 on: April 18, 2015 - 11:20:10 AM »
I added a 6mm spacer to the rear and am not willing to run them with the stock studs. I don't feel there is enough thread engagement. I have American Racing Torque thrust wheels. I'm installing 3" studs cut down to fit.  :2cents:
Offline RCCDrew
« Reply #7 on: April 18, 2015 - 11:52:56 AM »
Thanks for the input.
