Author Topic: Ideas ? Car dies in drive ....  (Read 2590 times)
Offline 74fish
« on: April 16, 2015 - 06:20:41 PM »
I have a 340 four barrel Holly double pump , street cam, headers. The cam is nice and prominent at idle but when I put it in D or R it dies immediately. No loose hoses or vacuum ports. Tightened the intake and carb. After it stalls it will not start without priming the carb. Checked and it looks like it's getting gas. Plugs had carbon... Ideas? :(
Offline 73440
Re: Ideas ? Car dies in drive ....
« Reply #1 on: April 16, 2015 - 09:55:30 PM »
What rpm's at idle?
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 74fish
« Reply #2 on: April 17, 2015 - 12:27:46 AM »
I have the RPMs pretty at around 1000.  I push on the gas and it will still die, Going to check the timing tomorrow and check the idle mixture screws.
« Reply #3 on: April 17, 2015 - 06:37:07 AM »
Had this problem with stock Carter, Idle Transition Slots exposed was the issue.
Covered in this article about half way down.  http://www.superchevy.com/how-to/45638/
Read up on brother CP's method of timing a Mopar... http://www.cuda-challenger.com/cc/index.php?topic=13018.msg132114#msg132114
« Last Edit: April 17, 2015 - 06:44:16 AM by Bullitt- »
Offline SirRalliart
« Reply #4 on: April 17, 2015 - 06:48:52 AM »
We had a similar thing happen with the Holley DP on my wife's '71 Challenger 440.  We replaced the accelerator pump and it works fine now.  Apparently they have a tendency to blow out on a back fire.
1971 Dodge Challenger R/T (Top Banana)
1972 Plymouth 340 Duster (TX9 Black)
1974 Plymouth 'Cuda360 (Deep Sherwood Metallic)
1978 Plymouth Volare Street Kit Car (#43, 2-tone Blue)
2014 Dodge Ram 1500 (Pitch Black)
2015 Dodge Charger SE (Granite)
2015 Dodge Callenger Hellcat (Phantom Black)
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: April 17, 2015 - 02:48:01 PM »
Is that idle RPM in neutral or Drive????
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline 74fish
« Reply #6 on: April 17, 2015 - 08:53:47 PM »
Can't even put it in drive with out revving it. Checked the idle mix screws .... out at  1.5 turns timing was about 15... couldn't see the mark so it was more than 10.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: April 17, 2015 - 10:00:29 PM »
SO that's 1000 RPM in Neutral...
All the tuning should be done with the car is drive.
If the timing was also checked in Neutral, it may be a little low once you pull it into Drive and causing the problem as well.
I would turn the idle speed screw up a bit and see if you can get it to idle in drive.  Even if it is idling high, at least you can recheck the timing in Drive and see where that is.
If you can get it to idle in D I would then drop the idle a little at a time and tune the accordingly.
Jason
74 'cuda 360/727
« Reply #8 on: April 21, 2015 - 11:13:36 PM »
Get the timing up , you want 14* or so at idle , 36* total & lose the vacuum advance
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: May 08, 2015 - 10:37:07 AM »
any updates on this?
Jason
74 'cuda 360/727
