What do you guys consider the deciding factor on when you go with a door skin?
Passenger door is loaded with filler. Already used paint stripper four times and have a pile of filler. Then used wire wheel and nylock wheel and it is still loaded down.
Really wanted to save as much original as I can, but I think this door is probably shot. Just don't know if I should spend more time do more stripping and see just how bad the dents are and try to fix them for practice. Or if I should simply cut my losses invest time elsewhere and spend the money for a skin.
