Author Topic: 4-Speed Bellhousing Question  (Read 2320 times)
Offline elevenssc
« on: April 18, 2015 - 02:45:59 PM »
Ive got the alignment dowel offset figured out, but I have a question about the parallelism between the engine mounting surface to the transmission mounting surface. How much out of parallel is allowed?
Looking at the trans mounting surface of the bellhousing toward the front of the motor, I'm about .005" low at 6:00 when grounded on the engine mounting surface.  (tail of trans would be below centerline. ). Is this a concern?  Getting things parallel and perpendicular to the trans pilot bore seems like a lot of work. Is .005" something I need to correct?
Thanks
Offline 73440
Re: 4-Speed Bellhousing Question
« Reply #1 on: April 18, 2015 - 06:33:53 PM »
a 1/64'' is .015 '' so that is 3 times .005''
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline elevenssc
« Reply #2 on: April 18, 2015 - 07:30:45 PM »
73440...is the .015" max allowed?  If so, I'm good to go...
Offline 73440
« Reply #3 on: April 18, 2015 - 09:25:22 PM »
I see a spec for "clutch housing face squareness" of .006'' Max. for the 3 and 4 speeds.
Not sure if that will translate where you are measuring.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline jimynick
« Reply #4 on: April 18, 2015 - 10:13:50 PM »
Boys, .005 is five one thousandths and .015 is fifteen one thousandths. does that help?
Offline elevenssc
« Reply #5 on: April 18, 2015 - 11:08:54 PM »
Just lookin for what is the max out of parallel allowed?  Still confused  :1zhelp:
« Reply #6 on: April 21, 2015 - 01:25:25 AM »
I am guessing you would have to mill the belhousing face to correct it
Offline bigblue73
« Reply #7 on: April 21, 2015 - 03:51:48 PM »
The input shaft on the 833's can take a large amount of offset and out of parallelism.  The number that sticks to my mind is .015 each way.  If you are not using an 833 then the specification may be tighter.  The assembly tolerances used today and tighter by a large margin than that of yesteryear.  AT .005 out of parallelism you can shim the bottom hole to gain the perfect zero indication.
