Author Topic: Pro Billet Distributor?  (Read 9747 times)
Offline JoeGrapes
« on: April 18, 2015 - 08:12:20 PM »
Has anyone tried one of those Pro Billet Distributor #6614 that are on E-Bay for around $50? Looks like a MSD knock off. The price seem so cheap compared to the MSD one.
Offline Mikey340
Re: Pro Billet Distributor?
« Reply #1 on: April 19, 2015 - 11:09:34 AM »
I put one in my small block 340 and so far it has worked fine.  The car started right up once I got the timing set.  Time will tell.
Offline brasil
« Reply #2 on: April 19, 2015 - 01:36:21 PM »
I would buy   TWO ...  so you have  one in  reserve.  Just in case
Greetings Juergen
Offline cudabob496
« Reply #3 on: April 19, 2015 - 08:06:16 PM »
$50???
That means cheap, will fail you soon, I suspect,
or give you poor performance!!
2011 Kawasaki Z1000
Offline Gumby
« Reply #4 on: April 19, 2015 - 10:37:07 PM »
Lot's of people reccomend Firecore. I realize we are trying to cut costs. http://www.manciniracing.com/bileldis.html
But $50.00? REALLY? What do you exspect for a $50 piece of chinese junk? You may have spent thousands on getting your engine rebuilt, and expect a $50 dollar dist. to control it all?
Good luck, buddy. Not trying to be demeaning. I had the same question about valvetrain. Was eyeing the Scorpion lifters. Every reply I got, was that VALVE train was NOT one area that you want to skimp on.
Finaly decided to bite the bulet and go with the retro-fit hyd. rollers. Avoid two issues with one stone, as it were, lol. It sucks. It costs money. But in the long run, it's cheap insurance.
$50.00 these days will buy you a couple of pizzas and a couple cases of beer. Maybe not that much. is it worth it for you to find out?
« Last Edit: April 19, 2015 - 10:43:08 PM by Gumby »
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline 734406pk
  • Andy
« Reply #5 on: April 19, 2015 - 11:29:29 PM »
Exactly! You get what you pay for! Even if these things were free, I wouldn't trust my engines survival to it. Don't want to skimp on something as important as a distributor. Not trashing the product but I would feel better using an MSD for ignition.
Offline 734406pk
  • Andy
« Reply #6 on: April 19, 2015 - 11:42:35 PM »
I would not trust my engine to this distributor. I'd rather spend the money for an MSD with a warranty.
« Reply #7 on: April 20, 2015 - 04:10:15 PM »
I have seen the MSD fail just as fast & a warranty won't pay the $250 tow bill home !!
 2 for $100 & the first could outlast the MSD
« Last Edit: April 20, 2015 - 04:32:34 PM by Chryco Psycho »
Offline roadman5312
« Reply #8 on: April 20, 2015 - 04:25:54 PM »
I will never use MSD again   :2cents:
Offline Aracer
« Reply #9 on: April 21, 2015 - 02:09:51 AM »
Skip White brand uses, the Pro-Comp cap and rotor, and comes with a female cap, but you can use the terminal, wire holder, positive type, too. It has to have the total advance stops bent towards the center to get:  16+ initial and 38* total. The pick up is a large Ford type and the only obvious weakness is the color of the wire, brown and black, brown is positive and goes to the green CD trigger wire.  It comes with no wiring code. It seems to work fine.
Offline cudabob496
« Reply #10 on: April 21, 2015 - 02:29:17 AM »
My MSD distributor has worked flawless for 15 years.
And engine always pulls strong up to 6000 rpm.
though a replacement cap one year did not vent well,
and moisture built up. Drilling a hole in cap solved that.
I doubt a $50 distributor would perform solidly for
a long time, especially at 6000 rpm. Just my opinion, though.
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: April 21, 2015 - 09:17:44 AM »
I would not be surprised if they were made in the same factory.
Offline RCCDrew
« Reply #12 on: April 21, 2015 - 10:21:35 AM »
My recurved stock distributor does just as well.
« Reply #13 on: April 21, 2015 - 12:35:49 PM »
I had one of the new all in one MSD dists in a 451 stoker , [customer choice] it lasted approx 1 week , not daily driven even & failed 200 miles from home at a car show....  only $250 to get it flat decked home including the free miles CAA included  , if a stock ign failed any parts store could have got him home  :2cents:
Offline cudabob496
« Reply #14 on: April 21, 2015 - 12:39:52 PM »
Would not think a billit MSD distributor and a stock distributor
would perform the same, as far as spark quality, duration, and timing,
at higher rpms.
If MSD's were really poor, then the market would eliminate them, just as it did
the Demon carbs.
« Last Edit: April 21, 2015 - 12:41:36 PM by cudabob496 »
2011 Kawasaki Z1000
