Rob, i have not rebuilt anything, its had it since i purchased the car, the trans has been changed out at some point proir, the engine is original. No history on the trans. The motor was build Dec 12, 1972, car was Dec 18, 1972. it has a cast crank balancer. You would swear its a bad uni joint as that is the type of vibration however, sitting in P or N its there, If you are doing 60 down the interstate, knock it into N and let the revs drop, nothing, smooth as, bring the revs up and its back, click it into D and still there. So that tells me its either engine (which I'm doubting a little) or front half of trans. I had the trans pan off it not long ago just to check it and change oil when I purchased the car and all looked good inside, very little muck in the pan and oil was good, soe
, there is a trans mech local who has a trans dyno, I could bolt it up and spin it, at least it would tell me if its engine or trans. But a pain in the back end having to pull a trans
