Author Topic: How are converter weights attached  (Read 1003 times)
Offline crash340
« on: April 21, 2015 - 06:50:10 PM »
Team, I have to trim/thin my converter weights, how are the attached to a factory converter please, if I shorten both ends with a dremmel cuttoff wheel will the remainder fall off or if I grind it thinner will it fall off???
Greg
73 Cuda
Brisbane, Australia
Offline Katfish
  • 70 Challenger
Re: How are converter weights attached
« Reply #1 on: April 21, 2015 - 07:05:31 PM »
I cut this 1 off, should be able to cut the weld.
Offline crash340
« Reply #2 on: April 21, 2015 - 07:18:21 PM »
Thanks Katfish, my converter is an earlier 360 unit with the two weights either side of the drain plug, no visible sign of weld
Greg
73 Cuda
Brisbane, Australia
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #3 on: April 21, 2015 - 07:52:29 PM »
They are induction or resistance welded on which means the 2 dimples on the weight in the picture are the attachment points to the converter.  By induction welding it doesn't ad weight to throw off the balance and its faster with out the heat distortion of a conventional weld
Offline jimynick
« Reply #4 on: April 21, 2015 - 09:09:23 PM »
Be careful! You're only about .030-.040" away from buying a new converter. Remember that the welding will make the weight and converter housing one piece. Slow and easy and careful is the game.  :cheers:
Offline crash340
« Reply #5 on: April 22, 2015 - 05:32:59 AM »
thanks guys, so, if they are effectively more or less spot welded onto the converter, I should be able to thin them out and or trim the ends a little without problem ?
Greg
73 Cuda
Brisbane, Australia
« Reply #6 on: April 22, 2015 - 06:00:05 PM »
should be fine  :2thumbs:
