Bad ground rear Cuda 71
Author Topic: Bad ground rear Cuda 71  (Read 2434 times)
Offline andben
« on: April 22, 2015 - 04:49:06 AM »
Guys, I dont know how the rear brakelights and stuff ground to the chassi? Everything is painted like three times.
Can someone explain how to get better ground to the right and left parkbrake and reverse-light?
e-body for life
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Bad ground rear Cuda 71
« Reply #1 on: April 22, 2015 - 07:42:24 AM »
1. Take your pocket knife or similar object and scrape away the paint around the socket area where the bolb plugs in.
2. Check your grounds off the motor to the body are they good?
3. Run a ground wire from the battery to the back of the car eather as a test or permanent solution.
Good luck.
Go Fast & Have Fun...
Offline Finoke
« Reply #2 on: April 22, 2015 - 10:10:10 AM »
The light socket is grounded by pushing it into the tail light housing.
The tail light housing is grounded because it's screwed to the body.
The body is grounded with the wire from your  radiator support to your negative terminal.
Clean all those connections with some fine sand paper.
It also helps to run an 8" ground wire from each tail lamp assembly directly to the body.
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: April 22, 2015 - 01:23:23 PM »
All good suggestions and they should fix the issue you are having.
I run extra grounds on my, engine to frame, transmission to frame and rearend to frame to help eliminate grounding issues.
Offline ec_co
« Reply #4 on: April 22, 2015 - 01:29:51 PM »
you may also want to use some dielectric grease - electrically conductive and will help seal bare metal from rusting in the future
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: April 22, 2015 - 01:30:18 PM »
Offline andben
« Reply #6 on: April 29, 2015 - 05:41:24 AM »
Yes lamp socket is grounded to the light housing.
Tail light housing is NOT screwed to the chassi anywhere on 71 cuda. Its monted with bolt from the outside part.. !?
I got good ground from BATT- to the chassi and big to motor, and motor to firewall.
I now run a small ground to the bolt/nut to the light houseing from chassi but it's doesnt look good :)
Appreciated guys!
e-body for life
Offline Katfish
  • 70 Challenger
« Reply #7 on: April 29, 2015 - 06:22:59 AM »
Dielectric grease is a non-conductive, silicone grease designed to seal out moisture and, therefore, prevent corrosion on electrical connectors. Being non-conductive, it does not enhance the flow of electrical current.
Offline YO7_A66
« Reply #8 on: April 29, 2015 - 07:19:59 AM »
When I bought my 70 Challenger some 13 years ago, it was freshly painted from the previous owner. It was not driven much at that time and I had the same issues with the rear tail lights as you. I had to do the same as the others by adding an additional ground wire from the battery. I ran mine from the battery all the way back to the rear of the car. Then I ran a wire to each of the tail light housings, then one to the gas tank sending unit. Then last year I added an electric fuel pump and I used this same ground for the install.
 Adding this ground wire to the back of the car has taken care of all of my brake light issues and it made my gas tank sending unit more accurate to my gauge on the dash.
