Author Topic: Cheapy Fuel Pump  (Read 5087 times)
Offline cudabob496
Cheapy Fuel Pump
« on: April 22, 2015 - 08:41:10 PM »
Well, put this on my 496, with an 850 DP.  Pressure stays flat at about 5 psi.
Also, add is wrong.  The outlet is 5/16, then it has the 1/2 inch flare.  I assume I would not make it through a full
1/4 mile without running out of gas? When I went out, I only gave it about half throttle
at times! What a pain! Gotta buy a better pump.  The 6 to 8 psi they advertise is bogus!
Also, replaced my fuel pump rod. It measured about 5/100 in. shorter than the new one, due
to normal wear, I suspect.
http://www.summitracing.com/parts/crt-m4845/overview/year/1971/make/plymouth/model/cuda
2011 Kawasaki Z1000
Offline cudabob496
Re: Cheapy Fuel Pump
« Reply #1 on: April 22, 2015 - 08:49:05 PM »
so what is a good mechanical fuel pump for my car, that may
be around $100??
Maybe this is my best bet??
http://www.summitracing.com/parts/crt-m4862/overview/make/plymouth
« Last Edit: April 22, 2015 - 08:52:33 PM by cudabob496 »
2011 Kawasaki Z1000
Offline 734406pk
  • Andy
« Reply #2 on: April 22, 2015 - 09:02:58 PM »
How about the Carter CRT-M4862? 120 gph and 7-1/2 to 8-1/2 psi spec. $ 107.97. Might need a regulator though.
Offline cudabob496
« Reply #3 on: April 22, 2015 - 10:41:30 PM »
That'll probably be the one!
2011 Kawasaki Z1000
Offline stinger
« Reply #4 on: April 22, 2015 - 11:38:54 PM »
I'm running this one http://www.summitracing.com/parts/edl-1723/overview/         no complaints for what it's worth.
Offline cudabob496
« Reply #5 on: April 23, 2015 - 12:16:07 AM »
oh ya, saw that one.  Would get it, but need to be cheap for a while. Saving up for heads for my LS1 Trans Am.
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: April 23, 2015 - 03:58:12 PM »
Time to go electric!!!
 :sadwavey:
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: April 23, 2015 - 04:36:30 PM »
Or get a new fuel pressure gauge?
Offline cudabob496
« Reply #8 on: April 23, 2015 - 05:10:26 PM »
no, got a real accurate electric 2 and 5/8 dia gauge inside car
« Last Edit: April 23, 2015 - 05:13:42 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #9 on: April 23, 2015 - 05:39:05 PM »
real, accurate, inside the car, electric is pretty much an oxymoron
Offline cudabob496
« Reply #10 on: April 23, 2015 - 05:51:14 PM »
It cost $120. I has to be accurate!
2011 Kawasaki Z1000
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: April 23, 2015 - 08:35:19 PM »
LOL
Offline cudabob496
« Reply #12 on: April 25, 2015 - 01:46:18 PM »
Got this email from Holley:
Thanks for contacting Holley Performance Products. Volume is more important than pressure when selecting performance fuel pump. For example a 500 hp engine will need 85 gallons per hour. I hope this helps.
2011 Kawasaki Z1000
