Author Topic: TTI Hanger question  (Read 5951 times)
Offline FY1Cuda
TTI Hanger question
« on: April 22, 2015 - 08:49:06 PM »
The E-body TTI hangers have one side wider than the other.  Does the wide side go inboard or outboard?
Offline Katfish
  • 70 Challenger
Re: TTI Hanger question
« Reply #1 on: April 22, 2015 - 10:57:57 PM »
Really?  I only used 1 for my driver's side since the passenger side already had something.
Almost certain they were symmetric/same.
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: April 22, 2015 - 11:21:48 PM »
Hmm!  I didn't notice that when I installed mine!  Call TTI and ask them.  They are great people and will make sure you are completely satisfied.
Offline shawge
  • Zoiks!!
« Reply #3 on: April 23, 2015 - 01:22:59 AM »
Yes, there is an offset to the hangers.
- Jerry
Offline YO7_A66
« Reply #4 on: April 23, 2015 - 06:37:37 AM »
 When I installed my TTi exhaust over the Winter, I just flipped the brackets until they fit the best. I did not buy their mufflers, so I just adjusted the brackets (side to side, left/right) until the mufflers fit. The Ebody brackets are very nice pieces! Just loosen the bolts a tad until you have them where they fit, then tighten them down.
Offline anlauto
« Reply #5 on: April 23, 2015 - 06:52:51 AM »
This is outlined in the instructions :2thumbs:
Offline 1 Wild R/T
« Reply #6 on: April 23, 2015 - 11:33:11 AM »
TTI's hangers are freaking Huge! And Ugly.... I tossed they one they sent me... No way something that ugly goes on my car..
Offline anlauto
« Reply #7 on: April 23, 2015 - 11:50:10 AM »
Paint them black :2cents:
Offline Katfish
  • 70 Challenger
« Reply #8 on: April 23, 2015 - 02:20:47 PM »
If you take it apart and flip that top piece, aren't they the same?
All same pieces, just a matter of how its bolted together?
I thought you were talking about the bracket that bolts to floor pan.
Offline anlauto
« Reply #9 on: April 23, 2015 - 02:21:38 PM »
Yes that is correct :thumbsup:
Offline 67vertman
« Reply #10 on: April 23, 2015 - 10:53:01 PM »
I must have gotten lucky when I installed mine and got the right the first time.   :smilielol:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #11 on: April 24, 2015 - 07:44:48 AM »
I was kinda thinking the same thing , any extra space in this area is a plus, I thought about making something more compact... painting them black is a good idea Alan . 1wildRT, what did you use to replace them with?
« Reply #12 on: April 24, 2015 - 01:24:40 PM »
At noon time today , I tooka look at the hangers, the top plate is 1/4 thick (I thought that is kinda excessive) The sides and the hardware all together weigh over 5lbs a pair and take up a good bit of real estate. I am not sure why they are so big and bulky.., I might call the engineer over there..I was thinking of welding the pipes together and using a clamp and a muffler hanger , when I assemble my car.
Offline anlauto
« Reply #13 on: April 24, 2015 - 06:53:16 PM »
You're building a custom car....I would remove all signs of the factory hangers and clean up their entire location. Then make a small discrete hanger welded to the floor, supporting the system just in front of the stock muffler location and weld the tail pipes to the mufflers :2cents:
« Last Edit: April 24, 2015 - 09:59:03 PM by anlauto »
Offline 1 Wild R/T
« Reply #14 on: April 24, 2015 - 09:55:42 PM »
I used a basic muffler hanger as pictured below with a 3" muffler clamp... The top strap is ugly but since it needs to be short I actually ground off the head of the rivet attaching that strap & the bolt that goes to the stock hanger goes through that hole... Turned out pretty clean for very few $$
