Author Topic: reverse thread wheel studs- Anyone else have these?  (Read 6230 times)
Offline all4rocks
« on: April 23, 2015 - 10:46:54 PM »
My 70 cuda I just got has all reverse thread wheel studs. My other 70 cuda doesn't have these. Why would you do that?
Offline 67vertman
  • Member since 9-23-2005
Re: reverse thread wheel studs- Anyone else have these?
« Reply #1 on: April 23, 2015 - 10:50:19 PM »
Someone swapped out the left hand threads on one car.  ALL 1970 came with right and left hand threads.
Offline all4rocks
« Reply #2 on: April 23, 2015 - 11:17:14 PM »
Mine only has it on the drivers side.  that is normal? My 70 chally didn't have reverse at all.
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: April 24, 2015 - 12:16:08 AM »
Drivers side is correct
Offline CudamanTom
« Reply #4 on: April 24, 2015 - 07:08:32 AM »
Mine too. I got rid of that mess when I converted to disc brakes.  :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Mopar Thunder
« Reply #5 on: April 24, 2015 - 07:12:18 AM »
My 70' Cuda was changed prior to my ownership, it has all righthand threads but my 68' Charger has lefthand threads on just the rear drivers side tire which I plan on changing out.
« Reply #6 on: April 24, 2015 - 08:52:02 AM »
70 was the last year , up until then all Mopars had left thread on the left side & right on the right side . 71 everything went to right all the way around
« Reply #7 on: April 24, 2015 - 09:28:11 AM »
This is normal, as pointed out by others. Your challenger was changed over prior.
Offline roadman5312
« Reply #8 on: April 24, 2015 - 09:39:46 AM »
Always wondered why they did that   :dunno:   Would tend to keep the lugs from backing off   :clueless:
Offline drewcrane
« Reply #9 on: April 24, 2015 - 09:58:05 AM »
Rolls Royce did it too , who knows :dunno:
« Reply #10 on: April 24, 2015 - 10:05:16 AM »
Don't throw out the studs if you change them out.  No one makes a LH stud anymore.  Some restoration guy will want them.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: April 24, 2015 - 11:20:05 AM »
Offline Strawdawg
    • Vortex Buicks
« Reply #12 on: April 24, 2015 - 11:21:49 AM »
That is exactly why they did it
Offline edl94
  • She Cuda
« Reply #13 on: April 24, 2015 - 11:23:22 AM »
It did not end in 70 my 73 had them on the drivers side.
« Reply #14 on: April 24, 2015 - 12:37:47 PM »
Yes, it ended in 1970.  Your 73 was changed at some point.  My October 72 built 73 has all RH.
I think Barry Washington posted the factory TSB that stated when LH lug nuts were stopped.
« Last Edit: April 24, 2015 - 12:43:07 PM by burdar »
