Author Topic: lift question  (Read 3687 times)
Offline Sleepychallenger
lift question
« on: April 23, 2015 - 11:41:38 PM »
On your normal 70 383 hp, how tall lift on the cam before you have to start worrying about hitting a piston...just in general? I have stealth heads and a cam under .500 But was thinking g of going above 500. Thanks for any input
Offline 73restomod
Re: lift question
« Reply #1 on: April 24, 2015 - 07:24:38 AM »
Anything above .500 and you need to check piston to valve clearance, just to be on the safe side.  Main reason is depth of factory piston reliefs.
Re: lift question
« Reply #2 on: April 24, 2015 - 08:48:28 AM »
Usually you are good to .520  but worth checking above .500
Re: lift question
« Reply #3 on: April 24, 2015 - 09:07:45 AM »
So pull the head, tdc, play doh on top of piston, then...?
Offline HP_Cuda
  • Mopar or No Car!
Re: lift question
« Reply #4 on: April 24, 2015 - 11:21:13 AM »
PTV baby!
Re: lift question
« Reply #5 on: April 24, 2015 - 01:41:26 PM »
PTV?
Offline HP_Cuda
  • Mopar or No Car!
Re: lift question
« Reply #6 on: April 24, 2015 - 04:46:36 PM »
PTV = Piston to Valve clearance
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: lift question
« Reply #7 on: April 24, 2015 - 04:57:53 PM »
I think what he is aking is what next. The way I do it is: pull the head and put play-doh ontop the piston and I spray the valves or play-doh with cooking oil so the play-doh doesnt stick to the valves then Put the head on with out headgasket and tighten lightly then rotate 2 complete revolutions  then remove head and measure the play-doh. I slice the play-doh to make it easier to measure
Re: lift question
« Reply #8 on: April 24, 2015 - 06:14:16 PM »
You should not have to pull the head , you can pull the valve spring & use a light checking spring & rotate the engine over & check how far you can depress the valve , but this is not as easy as it seems as the closest distance is usually 10* or so before TDC for exhaust & 10* after TDC for intake but eventhat can vary by a few degrees
