Author Topic: What ecu to use?  (Read 4613 times)
Offline brotow
  • There really is a Challenger in the backround
What ecu to use?
« on: April 24, 2015 - 07:11:19 PM »
My 70 challenger will have a 340 and I have an small block electronic distributor. What would be a good ecu and which ballast resister 2 or 4 pin?
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Re: What ecu to use?
« Reply #1 on: April 24, 2015 - 07:22:15 PM »
Brother CP always recommends the Mopar Chrome Box, I was just on RockAuto & they have some clearance priced ECU's & ballasts.
All the conversion kits come with the 2-terminal ballast and from what I understand the newer ECUs don't need a 4-terminal
Offline anlauto
« Reply #2 on: April 24, 2015 - 07:53:19 PM »
REV-N-ATOR :2thumbs:
Offline blown motor
« Reply #3 on: April 24, 2015 - 10:38:28 PM »
« Reply #4 on: April 24, 2015 - 11:13:26 PM »
The best there is for the price.
Distributor is pre curved to your set up.
http://www.4secondsflat.com/Ignition.html
12 volts to the coil.
3 year warranty
« Reply #5 on: April 24, 2015 - 11:36:04 PM »
the Rev-n-ator is awesome but there seems to be some reliabilty issues
 I used approx 5 of the FBO kits & the car ran better with every FBO piece removed & replaced , maybe his limiter box is better quality as I have not tried those
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #6 on: April 24, 2015 - 11:51:28 PM »
 :popcorn: :popcorn: :popcorn:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #7 on: April 25, 2015 - 07:54:09 AM »
I'd go with an MSD box. I swapped out a chrome box for an MSD 6 and starting and bottom end were much improved. Pulls harder from a stop and starts with very little starter engagement. And you get rid of the ballast resistor entirely.  :2thumbs:
Now excuse me while I get into my nomex suit before CP flames me.  :grinyes:
Offline tman
« Reply #8 on: April 25, 2015 - 10:55:02 AM »
FBO looks good and eliminates ballast resistor.
« Reply #9 on: April 25, 2015 - 04:47:21 PM »
Not going to flame you , I am glad it is working for you  :2thumbs:
Offline RCCDrew
« Reply #10 on: April 26, 2015 - 12:31:30 AM »
This is a good thread. I'm running an orange box and am ready to step up a notch or two.
Offline tman
« Reply #11 on: April 26, 2015 - 12:58:10 AM »
The only negative thing I can say about the FBO, is the commercialization on the cover.  At least make it look stock orange, chrome, or gold with an FBO logo or something.
Offline blown motor
« Reply #12 on: April 26, 2015 - 09:46:53 AM »
That's one of the reasons I like the REV-N-NATOR and results from it have been flawless.
Offline dsburch
  • Twice, slowly.
« Reply #13 on: May 17, 2015 - 10:54:07 AM »
If you go with the FBO HRR688 and the 40011 coil be sure to go with vertical mount for that coil.  I went with the 40111 which is epoxy filled so I could mount on the intake like stock.  The 688 and 12v coil which bypasses or does away with the resistor is working well so far, only a couple hundred miles, but very pleased, and with the same characteristics as the MSD comments.  (I can't comment on another product I have not tried.  All can be good... your mileage may vary.  :grinyes: )  Working fine with the old MP electronic dist, yes - Don says make sure the pick-up coil is not weak, so I refreshed it.
Offline polarbear123
« Reply #14 on: May 17, 2015 - 11:26:27 AM »
I have had the Rev-N-Ator for 2 years works great.
