Author Topic: What ecu to use?  (Read 4612 times)
Offline cjd automotive
    • The Shop
Re: What ecu to use?
« Reply #15 on: May 22, 2015 - 06:05:32 PM »
No one is suggesting the MSD E-curve distributor?  I've put several of these on 340/360's to eliminate the ignition box failure.  They have a built in MAP sensor that is connected to engine vacuum and the ability to set some very usable ignition curves. Also has a built in rev limiter.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
www.STREETANDRACEPERFORMANCE.com
Jacksonville, FL 32220
904-400-1802
