G3 Hemi Install Pic's
Author Topic: G3 Hemi Install Pic's  (Read 9408 times)
Offline 3D
« on: April 26, 2015 - 09:54:48 AM »
Let's see your G3 hemi motors. I'd like to see how much clearance is on all sides/angles.
Thanks in advance.
Offline GoodysGotaCuda
Re: G3 Hemi Install Pic's
« Reply #1 on: April 26, 2015 - 03:58:46 PM »
I have a lot of clearance around mine, heck, I can walk around it!
 :bigsmile:
...I'm workin' on that whole "in the car" thing.  :working:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #2 on: April 26, 2015 - 04:56:56 PM »
 :bigsmile:
:roflsmiley:   Here are a few with the Alterkation Coilover suspension
Offline 3D
« Reply #3 on: April 28, 2015 - 02:25:48 PM »
You should be honored to have the only 'Cuda with a G3 Hemi!!!
Come on guys, lets see some pic's.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #4 on: April 28, 2015 - 05:51:21 PM »
If your on Facebook there is a section on 3G hemi installs...
https://www.facebook.com/groups/750056585062561/photos/
Enjoy... :picture:
Go Fast & Have Fun...
Offline Sleepychallenger
« Reply #5 on: April 28, 2015 - 05:53:21 PM »
Dan don't you have the pictures of Geralds installed?
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #6 on: April 28, 2015 - 07:47:57 PM »
Here is the pics of when we dropped the 6.4 in his '73 with an RMS front clip to mock it up.
Offline 3D
« Reply #7 on: April 29, 2015 - 01:30:57 PM »
Enjoy... :picture:
Already on it!
    • THE DODGE BOYS
« Reply #8 on: April 29, 2015 - 09:10:51 PM »
Already on it!
Cool, Then what more do you need?   :ylsuper: :bananasmi :bigshades:
Offline grimmey71
« Reply #9 on: April 30, 2015 - 07:34:10 PM »
Offline 3D
« Reply #10 on: May 01, 2015 - 10:14:39 AM »
Thanks DFRAZZ.
I'm Just looking for pictures to see how much room there is with the G3 hemi.
I have a '70 Cuda I'm working on and I have two running motors I can use but I cant make up my mind.
1) 360 LA motor w/727 trans (complete donor truck).
2) 2004 5.7 Hemi w/545RFE trans (complete donor truck).
I like the newer Hemi for the weight, hp, roller valve train, reliability and made for today's oils, but I want the car to have a lopey idle, and it looks like the only cam I can use is the SRT MAX. If I use the 360 motor the installation is a breeze and I can install a lumpy cam.
keep in mind both motors are running and I don't really want to dive into the 5.7 to install different pistons.
I need to buy the gas tank so I could buy the EFI tank from tanks inc.
 :banghead: :dunno:
« Last Edit: May 01, 2015 - 10:17:19 AM by da4ad »
Offline dfrazz
« Reply #11 on: May 01, 2015 - 10:47:20 AM »
Thanks DFRAZZ.
 :banghead: :dunno:
The 5.7 will also require a new harness too.
Offline 3D
« Reply #12 on: May 01, 2015 - 11:12:30 AM »
I would just modify the stock harness.
Offline daryld
« Reply #13 on: June 12, 2017 - 10:40:04 PM »
Did you have to modify the firewall at all to get the 6.4 in your E body?
quote author=dfrazz link=topic=105983.msg1040926#msg1040926 date=1430264877]
[/quote]
Daryl
« Reply #14 on: June 13, 2017 - 01:37:21 AM »
No. All of the gen 3 engines are externally the same size. Intake height may vary a little, but not much.
1976 Dodge Warlock
