Author Topic: Rear defogger switch question  (Read 893 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: April 26, 2015 - 04:15:56 PM »
After conferring with this post:
http://www.cuda-challenger.com/cc/index.php?topic=79469.0
I need to know if the lowest position on the switch is off, then up one = low speed, and then top = high speed. Seems a bit weird since the power input on the rear of the switch is in the middle but hey I guess it's possible.
Thanks in advance!
Bryan
Offline Rich G
Re: Rear defogger switch question
« Reply #1 on: May 12, 2015 - 03:42:37 PM »
On my 71, down is off, middle low and top high
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: May 13, 2015 - 01:58:22 AM »
Thanks Rich!
I also found this schematic for those in the same boat:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: May 22, 2015 - 07:53:41 PM »
I guess I'm back to square one and I'm getting tired of pulling the dash apart every time I think I'm done.
I have posted the schematic which I believe is applicable to Cudas and Challengers.
So here is my question, the access feeds under the dash  - they both have power at the same time or ??? I noticed the schematic calls for plugging it into the tan access feed but I think that both access feeds are powered once the car is keyed on. no?
So I have power running to the middle pin of the switch and the bottom pin used to run a accessory like a wiper fluid motor. When I turn on the power I get nothing when it's in the middle position but 11V at both the top and the bottom positions. This must mean I am using the switch wrong. See the pic where there are 3 pinouts and the middle one I thought based on the schematic is for power, no?
Any ideas?
« Last Edit: May 22, 2015 - 07:57:34 PM by HP_Cuda »
