Author Topic: Door panel and door handle replacement.  (Read 1522 times)
Offline 74 challenge
« on: April 29, 2015 - 07:45:17 AM »
Hey guys,
I am going to be replacing my door panels and my outside door handles. Does any one have any step by step instructions for either of these parts?
Thanks!
1-8-4-3-6-5-7-2
Offline CudamanTom
Re: Door panel and door handle replacement.
« Reply #1 on: April 29, 2015 - 08:00:33 PM »
Well for my cuda...
Remove the door panel screws along the sides and bottom.
Remove the bezel for the remote drivers side mirror if equipped.
Loosen the door lock lever in the arm rest.
Pop out the bottom clips of the door panel.
Pull panel slowly away from the door while lifting and managing around the inside door latch handle.
Once panel is removed, unclip the lever rod for the door handle.
Loosen the nuts for the door handle and remove.
I think that's it. If I remember right.  :2thumbs:
Disclaimer... it might be a little different for a challenger.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Katfish
  • 70 Challenger
« Reply #2 on: April 29, 2015 - 08:22:45 PM »
Pretty much what I do, except:
First thing I do is remove the inside door handle.
Pull it open to access the Philips head screw holding it.
Offline blown motor
« Reply #3 on: April 29, 2015 - 10:38:00 PM »
My 74 door handle is held on with a hex head stud. Remove it before removing panel. No need to undo any lever rod.
Offline CudamanTom
« Reply #4 on: April 30, 2015 - 07:08:38 AM »
The lever rod is for the outside door handle, not the inside door handle. He wants to replace the outside door handles.
But I did forget about the two screws that mount the arm rest/panel to the door.
« Reply #5 on: April 30, 2015 - 07:19:46 AM »
Perfect you guys make this sounds pretty simple.
to access the outside door handles does the window need to be up?
1-8-4-3-6-5-7-2
Offline CudamanTom
« Reply #6 on: April 30, 2015 - 08:04:30 AM »
Nope.
Offline blown motor
« Reply #7 on: April 30, 2015 - 08:25:11 AM »
Gotcha. I was just referring to door panel. Forgot about outside handles.
