Author Topic: 518 questions  (Read 637 times)
Offline ChallengerHK
518 questions
« on: April 30, 2015 - 11:59:00 AM »
What would be a good max torque limit if I was going to install a lockup version of the 518?
Can the lockup trans be used as a non lockup trans, with no input from the third wire?
- Han Solo, Star Wars
Offline Katfish
  • 70 Challenger
Re: 518 questions
« Reply #1 on: April 30, 2015 - 12:51:50 PM »
If you don't connect the 3rd wire, it won't LU.
But why would you do that?  Benefit is lower RPMs and cooler operation.
Absolutely LOVE my 518.
Re: 518 questions
« Reply #2 on: April 30, 2015 - 12:55:46 PM »
A couple of the other sites I've been using to research this have expressed a surprisingly low torque number as being able to tear up the lockup feature (hence the first question above). If I exceeded that number, I'm wondering if I can just disconnect the inputs for lockup rather than having to find a non-lockup trans.
Offline Katfish
  • 70 Challenger
Re: 518 questions
« Reply #3 on: April 30, 2015 - 05:19:45 PM »
Well LU should only occur at 55mph or higher.
So do you expect to throw a ton of torque at it while going 55mph and 1800rpm?
If set up correctly, the LU will disengage when you get on it.
Re: 518 questions
« Reply #4 on: April 30, 2015 - 05:27:36 PM »
I did a program on the GM 4l60E several years ago. Lockup was failing because it didn't disengage properly or fast enough. Result was having to replace the transmission. Trying to prevent a similar result.
