Author Topic: Argent Trim Install  (Read 2604 times)
Offline Blasterb
Argent Trim Install
« on: May 01, 2015 - 10:47:48 AM »
I'm having trouble installing the rear argent trim on my 70 Challenger. I have the right clips but when I try and tighten the inside bolts the clips come right off. The bottom edge of the trim ends up about 1/3 of an inch from the car. I have 3 different assemblies and they all seem to fit the same way. Any ideas?
Re: Argent Trim Install
« Reply #1 on: May 01, 2015 - 10:51:45 AM »
Post a picture of the clips you have.
Offline Blasterb
« Reply #2 on: May 01, 2015 - 04:11:14 PM »
Here's the clip
Offline roadman5312
« Reply #3 on: May 01, 2015 - 04:30:12 PM »
There must be a trick to installing these . Had the same problem with an NOS piece.   So I just threw the dang thing away, filled in the holes and painted the tail panel black.   :misbehaving:
Offline cordodge
« Reply #4 on: May 01, 2015 - 04:55:29 PM »
installed mine never had an issue, some of the clips were a little loose fitting so i just gave them a little twang to snug them up in the piece. and i just snugged the nuts just a little passed hand tight :dunno:
hope this helps
bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline Blasterb
« Reply #5 on: May 01, 2015 - 05:19:05 PM »
hope this helps
bruce
That's what I tried first but then the trunk lock doesn't fit. Must be a trick to it.
Offline roadman5312
« Reply #6 on: May 01, 2015 - 05:25:48 PM »
                   The truck lock goes in first, thats what got me. Leaves a space between the panel and lock. But still could not get the lower clips to, well, clip.  :dunno:
Offline cordodge
« Reply #7 on: May 01, 2015 - 05:40:58 PM »
hmm,i will have to take a closer look at mine it fit great. roadman got me thinking about the trunk lock maybe i installed my lock after the panel cant remember?not home till may 11th though
Bruce
2007  Dodge Ram 4x4
Offline Blasterb
« Reply #8 on: May 01, 2015 - 06:35:36 PM »
Thanks for that tip. I , of course broke the lock putting it in. luckily I have a spare.
« Reply #9 on: May 01, 2015 - 06:40:59 PM »
 :popcorn:  Just learning.... I have one to install too.
Offline Blasterb
« Reply #10 on: May 01, 2015 - 08:00:24 PM »
That's the root of the problem, the clips just don't stay clipped!
