Author Topic: Mouse Trouble!  (Read 4971 times)
Offline steve g
Re: Mouse Trouble!
« Reply #15 on: May 10, 2015 - 05:51:21 PM »
I used the bucket trap this spring and caught 7 the first night and 5 more in the next few days. Put another in my parts shed and so far in a month, I'm at 22 mice total. Great trap to have all year round, will add antifreeze this winter!
Offline reborn73
Re: Mouse Trouble!
« Reply #16 on: May 10, 2015 - 07:54:00 PM »
First thing the "theory" that the bait makes them thirsty and they will leave to find water is 100% false.  So is the moth balls and dryer sheets.  Moth balls are made from a byproduct during the production of gasoline.  Naphthalene, the active ingredient in the moth balls will do more harm to you and your family than it ever will to deter rodents.
Get some good old fashion wooden snap traps and use a variety of "baits".  Use small pieces in the trigger.  Try chocolate, hard candy, bread, peanut butter or cheese.   Put at least 6 of the traps out in the floor board with one of the baits on each trap.  Mice are naturally very curious and will "check out" some new smell as soon as you leave and shut the door.  Be sure to check the traps every day.
Good luck
Re: Mouse Trouble!
« Reply #17 on: May 10, 2015 - 10:31:49 PM »
A thin film of Peanut Butter on the trigger of the mouse trap always works for me.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Mouse Trouble!
« Reply #18 on: May 10, 2015 - 10:57:04 PM »
D-Con  :aarg:
http://www.amazon.com/D-Con-Ready-Bait-Bits-Brodifacoum/dp/B00DMC9644/ref=sr_1_1?ie=UTF8&qid=1431312320&sr=8-1&keywords=d-con+bait+pellets
The active ingredient in d-Con is a chemical called brodifacoum.
One important aspect of brodifacoum is that it creates an insatiable thirst in mice and rats.
This often leads the mice to venture outside after eating the bait, in search of water. This reduces the number of rodents that die inside the walls of houses, crawlspaces or in your Mopar.  :violin:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
