Author Topic: 70 Challenger side mark light  (Read 2473 times)
Offline Jolly_Roger
  • Jolly Roger
« on: August 16, 2002 - 03:07:23 AM »
Hello
I was wondering how do you fix the side-marker light on the passenger front fender?? cause my burned out and I reached under but its like covered with some stuff.. can anyone help me out
thanks
Jolly Roger
Ready For Boarding
Offline camjam
  • Rare-it-T
Re:70 Challenger side mark light
« Reply #1 on: August 16, 2002 - 07:53:14 PM »
To remove the side marker light:
1. Working under the car, disconnect the wiring for the lamp from the main wiring harness. Remove the two capnuts attaching the lens to the bracket.
2. Carefully remove the lense assembly away from the fender on the outside and also remove the mounting bracket from the inside.
3. To replace the bulb remove the two screws from the back of the housing that attaches the lens assembly to the housing.
The bulb number is 1895
71 Challenger R/T 383 4spd - 1 of 10 known to have been built for canada - restored
70 Charger R/T SE 440 auto - restored
Offline Jolly_Roger
  • Jolly Roger
« Reply #2 on: August 16, 2002 - 11:08:59 PM »
Hey thanks...you've helped me out alot...
Ready For Boarding
