Steep driveway suggestions
Author Topic: Steep driveway suggestions  (Read 2165 times)
Offline dave73chally
« on: May 04, 2015 - 08:37:42 PM »
Buying a house and the driveway is somewhat steep, concerned with the challenger bottoming out. It somewhat dips down from the street into the driveway. Future plans are to tear it out completely and regrade but that won't happen for a few years. As a temp fix I'm thinking of dumping some gravel at the base to smooth out the dip, any other suggestions? Thought of ramps but that will get old real quick...
73 Challenger
Offline 67vertman
  • Member since 9-23-2005
Re: Steep driveway suggestions
« Reply #1 on: May 04, 2015 - 10:50:08 PM »
It is hard to tell from the picture...is your driveway gravel and the road asphalt or are they both asphalt?
If yours is grave then I would get some class II or Class III base and level out your end.  If they are both asphalt, get some asphalt cold mix and fix the grade.
« Reply #2 on: May 05, 2015 - 07:09:55 AM »
Both are asphalt, how long does cold mix take to fully cure and is able to be driven on?
73 Challenger
Offline AussieMark
« Reply #3 on: May 05, 2015 - 07:36:00 AM »
buy a different house
Offline djais1801
« Reply #4 on: May 05, 2015 - 08:45:36 AM »
sell the car...2 me-  ORRRRR do this:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: May 05, 2015 - 09:06:44 AM »
You need one of these
« Reply #6 on: May 05, 2015 - 03:49:07 PM »
Really considered that but not going to happen.
 :grinyes: I know the dip is there, I don't care if other people bottom out!
I have no words... :faint:
73 Challenger
Offline roadman5312
« Reply #7 on: May 05, 2015 - 04:00:43 PM »
Don't know where your new house is but that could be a PITA if you get snow/ice.
« Reply #8 on: May 05, 2015 - 06:42:20 PM »
All things I've thought of and am ready for, my daily driver car is not an issue. It's the challenger I'm concerned about
73 Challenger
Offline 67vertman
« Reply #9 on: May 05, 2015 - 10:20:44 PM »
Cold mix is instant once it is tamped/rolled in place.  You can get it 0.5 Cubic Feet bags at most hardware stores.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #10 on: May 05, 2015 - 11:55:51 PM »
 :iagree: Cold mix is the way to go.
« Reply #11 on: May 06, 2015 - 09:00:25 AM »
Any specific brands recommended over others? I'll most likely be buying from a chain like home depot/lowes.
73 Challenger
Offline 67vertman
« Reply #12 on: May 06, 2015 - 11:40:34 AM »
I am not sure about brands but one should be as good as another.
A couple of tips: before placing the mix.  Have someone drive the car while you watch where the car will bottom out. Place a couple of blocks of wood in the tire tracks and try again. You will soon see where and how much lift (Cold mix) you will need.  Before placing the cold mix, sweep (and or wash) the area thoroughly,  Let it dry if you washed it. If you have some old motor oil, or you can by some tach coat when you get the Cold Mix. Spread lightly within the area you plan to patch. Place the cold mix and spread evenly, a rake or 2 by 4 works good. Tamp the cold mix well. If you don’t have a metal tamper, I have used a block of wood.  If you follow these steps it should last a long time.
Offline 71gogreen
« Reply #13 on: May 06, 2015 - 11:53:17 AM »
cut out asphalt and build a 2x6 rectangular form .I would cement a pad between the 2 points. :smokin: :dogpile:
71challenger-millcreek park\71challenger-millcreek
Offline 67vertman
« Reply #14 on: May 06, 2015 - 01:28:21 PM »
 :swaying: He said he is looking for a temporary fix until he can re-do the whole driveway.  :2thumbs:
