Author Topic: Help - steering column rebuild , where does this spring go?  (Read 3546 times)
Offline twalker
For the swivel safety lever "to remove key - depress lever & turn key"
Re: Help - steering column rebuild , where does this spring go?
« Reply #1 on: May 04, 2015 - 11:34:46 PM »
I thought I sent you the e-mail:
Pay attention to the spring (release) on how it goes on that makes the key release when you normally turn on the ignition.
Put the key in the ignition slot in that part of the chapter to remove the cylinder.
You'll see!
Offline twalker
« Reply #2 on: May 05, 2015 - 06:33:20 AM »
Yep, got your email with the doc, it's helped a lot - but the column you did doesn't have this safety feature on the column, and this spring.  I'll send another photo later.
Sent from my iPad using Tapatalk
Offline twalker
« Reply #3 on: May 05, 2015 - 07:43:12 AM »
This is the piece that rotates on the column and is spring loaded.  It must be rotated to get the key out.  I forget how to install the spring above to keep it loaded.   Unfortunately my disassembly pics don't have it.
Offline anlauto
« Reply #4 on: May 05, 2015 - 08:06:01 AM »
I know exactly where it goes, but it's extremely hard to describe. It goes on the peg in the lower right-hand side of your first picture. The other end hooks to the tube of the steering column. You won't be able to see exactly where until you put those two pieces together.
Offline twalker
« Reply #5 on: May 05, 2015 - 08:09:20 AM »
Thanks Alan - I wondered about the peg, tried a few positions but didn't get it - will try again tonight now that I know it goes there.  Thanks again
If anyone has a picture - love to see it :-)
Offline twalker
« Reply #6 on: May 05, 2015 - 06:44:44 PM »
Ok, thanks Alan - figured it out.   Picture below for all those that follow.
Offline anlauto
« Reply #7 on: May 05, 2015 - 06:57:02 PM »
You got it pontiac :2thumbs:
Offline twalker
« Reply #8 on: May 05, 2015 - 08:32:58 PM »
Alan, do you recognize this and know where it goes?  Last piece that I can't find a home for.
Offline anlauto
« Reply #9 on: May 05, 2015 - 08:53:31 PM »
Oh that.....goes right next to that thingamagig.... :2thumbs:
Offline twalker
« Reply #10 on: May 05, 2015 - 08:54:27 PM »
Are you just toying with me now :-)
Offline twalker
« Reply #11 on: May 05, 2015 - 08:56:34 PM »
Here right?
Offline anlauto
« Reply #12 on: May 05, 2015 - 08:59:50 PM »
Are you referring to the rubber block ? If so then yes....My above non-descriptive answer  was due to the lack of attachment :blah: :smilielol:
Offline twalker
« Reply #13 on: May 05, 2015 - 09:00:48 PM »
Oops... Sorry ... Maybe it's break time or beer time....  Thanks Alan
Offline CudamanTom
« Reply #14 on: May 05, 2015 - 09:52:56 PM »
That's the wrong brand spring. That spring belongs to a ford. You need the blue spring.  :smilielol:
It matches the muffler bearing spring.  :bigsmile:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
