I have no experience with aftermarket A-pillars, BUT you should be able to lift up on the back of the dash assembly before you tighten up the two bolts in the kick panel area. That should take up any gap between the A-pillars and the dash pad. The dash doesn't have to sit all the way down on the two kick panel bolts. The dash frame is slotted so there is some adjustment there.
