Author Topic: suggestions quick fuel or holley??  (Read 10218 times)
Re: suggestions quick fuel or holley??
« Reply #30 on: May 07, 2015 - 08:27:38 AM »
hey thanks Brad, great looking carb and yeah might as well get the line set with it.   Bruce
If you need fittings/line I got mine here. Priced right and easy to assemble IMO
http://www.anfittingsdirect.com/
The hose is lined with PTFE  and is good for ethanol and FI pressures too. I went this route just in case I wanted to add FI at a later date?  Traditional hose like Aeroquip with rubber liner won't last with fuel left in them . Aeroquip salesman told me 1 year if fuel is left in them 4 year if not. FYI....
Offline cordodge
« Reply #31 on: May 07, 2015 - 08:33:52 AM »
Ok good to know brad, while i got you any suggestions on the line from the main fuel line to the pump
Bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline cudabob496
« Reply #32 on: May 07, 2015 - 03:01:48 PM »
Urich's chart suggests an 1150 and Vizard's forumula, if you assume the heads are not all that great (which is hard to do with a hemi) predicts a 1050.  there is a reason that the factory used dual quads on much smaller engines.
A 950 for a pure street car will start acting like a choke around 5300 rpm.
A 950 will choke a 572?  Maybe an 800 hp 572, but not a crate 650 hp 572?
2011 Kawasaki Z1000
« Reply #33 on: May 07, 2015 - 08:12:21 PM »
Bruce
I bought stainless 1/2" thin wall tubing and used Swagelok stainless fittings I sourced off E-Bay and amazon. Borrowed a buddy's tubing bender and " went to town"  I'm using a Mallory electric fuel pump with a regulator and a return. Also used fire sleeve to keep the lines cool around the exhaust.
« Reply #34 on: May 07, 2015 - 08:20:17 PM »
A few more if it gives you any idea's/help?
Return line in filler neck..
Offline cordodge
« Reply #35 on: May 08, 2015 - 03:32:48 PM »
hey, thanks for the pics brad, thats some big tubing! going to get some insulating sleaves for aroung the hot areas.
Bruce
2007  Dodge Ram 4x4
« Reply #36 on: May 08, 2015 - 08:24:30 PM »
I think Swagelok are the only compression (non-flare) fittings approved for gasoline aren't they?
« Reply #37 on: May 08, 2015 - 08:59:07 PM »
I'm not sure? :clueless:  I just bought them because they were stainless and had 8AN connections.  :lol: When I looked up the specs they are WAY overkill pressure wise. They are used in high pressure hydraulic applications.
