Author Topic: 518 OD yes-no??  (Read 1466 times)
Offline RAD1229
  • 72 Challenger
518 OD yes-no??
« on: May 17, 2005 - 09:10:09 AM »
OK,  I have pinpointed that i need a new converter for my 360-727 combo...........on the other hand, I did just run across a 3.91 posi unit.
So, how bad would it be to go to a 518 OD and use the 3.91's???  I am just thiniking here :dontknow:
 I know that the shifter brackets would have to be altered or changed, but I think i remember a few members here on the board that have this tranny?
Just looking for some opinions here,  I am not a racer, just like cruisin' around and burnin a little rubber here and there?  IS this a reasonable thing to be pondering, or should I just say "heck with it" and stick a converter into the 727? :dontknow:
1972 Challenger
Offline ragtopdodge
Re: 518 OD yes-no??
« Reply #1 on: May 17, 2005 - 09:45:26 AM »
I say go for it.  If you have the $$$.
I think you'll have to grind down some parts of the tranny case for it to fit, but no biggie.
Big deal is probably the wiring, but not too bad.  Here's a great site for the conversion:
http://www.transmissioncenter.net/alto_3.htm
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline RAD1229
  • 72 Challenger
Re: 518 OD yes-no??
« Reply #2 on: May 17, 2005 - 10:52:10 AM »
Thanks for the link ragtop,  I am just looking for the best thing to do.  I think that in the long run, I will get any money I put in back on gas?
thanks again for the link could end up being helpful!
1972 Challenger
Offline DodgeFreak
  • Cars and trucks are my friends..
Re: 518 OD yes-no??
« Reply #3 on: May 17, 2005 - 06:29:11 PM »
it'll be expensive and alot harder than you think......i've tried locating a 518 for my dads truck and they want anywhere from 600-2000 for a USED tranny.  also...wireing that thing will be a pain...but if you like wiring it wouldn't be to bad for you i guess...also the flex plate is different for 518 tranny is what i've been told..i haven't measured but i could if you really wanted to do the swap..
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline EFI-Cuda
  • 1974 Cuda 408
Re: 518 OD yes-no??
« Reply #4 on: May 17, 2005 - 11:08:35 PM »
I currently use an A-518 transmission and 3.91 rear gears in my Cuda.   It is a very nice combination for performance and road manners.   I got the transmission new directly from Chrysler.   There are two kinds of A-518 transmissions.   One electronically controls the engagement and disengagement of the overdrive gear with a button.   No other wiring necessary.    The other needs wiring to connect the lock-up converter in adddition to the engagement and disengagement of the overdrive gear.    This A-518 needs two buttons.   The A-518 that I have just requires a single button for the overdrive.   The wiring is a piece of cake.   It is just one button.
I put a transgo shift kit in the transmission which greatly improved it's feel.   I have posted info about the transmission's installation on the board already.   If you can find this post, it will answer a lot of your installation questions.
Cuda 408, Ford EFI, Magnum heads, Vortech V-2 Si-Trim, A-518 transmission and 3.23 gears.
Offline ragtopdodge
Re: 518 OD yes-no??
« Reply #5 on: October 09, 2006 - 06:13:59 PM »
Hey 1974Cuda,
I understand you got the 518 in.  Did you modify the trans or modify the tunnel/x-member to get it to fit?
Also, got a pic of your slapstick mod?
Thanks,
-rob
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline tactransman
Re: 518 OD yes-no??
« Reply #6 on: October 09, 2006 - 10:18:39 PM »
Flex plate is not different necessarily because of the 518, it is different because the magnum engine takes a crank sensor and an exciter ring (part of the flex plate) to run.You can use a 518 behind a 318/360 with the stock early model flex plate,converter bolt pattern is the same till you get to '96 and later then the bolt patttern is 90 degrees on the pads.(they moved the 5.9 liter balance weight to the flex plate) :thumbsup:
Terry-tactransman
Union, Mo.
Offline tactransman
Re: 518 OD yes-no??
« Reply #7 on: October 09, 2006 - 10:22:31 PM »
There are three kinds: non lock up (common '90 to '91 1/2)
                                    Lock up ('91 1/2  up)
                                    Computer shifted ('96 on)
Terry-tactransman
Union, Mo.
