Author Topic: 440 which headers???  (Read 6560 times)
Offline 440 SixPack
« on: May 06, 2015 - 04:27:01 AM »
Hi Moparfriends!
I am from Austria and my 71 Challenger R/T is 99% finished. The only thing I need is a set of good ceramic coated headers for my 440 with stock cylinder heads! Now I have two different stock manifolds on it...
My mechanic said that TTI are the best way to go but is there another good way? TTI are very expensive...
Thanks Moparfamily... :2thumbs:
Offline anlauto
Re: 440 which headers???
« Reply #1 on: May 06, 2015 - 06:51:26 AM »
My vote is also for TTI You get what you pay for :2thumbs:
Offline CudamanTom
« Reply #2 on: May 06, 2015 - 07:14:51 AM »
I have Hedman with my 440. Love em and didn't break the bank.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #3 on: May 06, 2015 - 07:30:49 AM »
TTI or Dougs , nothing else measures up
Offline djw383
« Reply #4 on: May 06, 2015 - 07:54:30 AM »
Regardless of what brand you decide on, I would buy an exhaust kit in the same brand. I had bought Hedman HPC headers years ago and recently used them. I liked the fit and finish but had some work to do to get the different brand exhaust to match up with the collectors.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: May 06, 2015 - 08:58:03 AM »
 :iagree:  They fit perfectly and look amazing!  You will forget the extra cost soon after you install them.
Offline 67vertman
  • Member since 9-23-2005
« Reply #6 on: May 06, 2015 - 01:32:35 PM »
I did the whole TTI kit, headers, mufflers and exhaust pipes, ceramic coated.  Pricey yes...worth the money?  Defiantly.
http://ttiexhaust.com/
Offline 4406v
« Reply #7 on: May 06, 2015 - 01:51:02 PM »
Another vote for TTI buy'em once and forget about it.
"Live for today, Tomorrow never comes"
Offline Fern
« Reply #8 on: May 06, 2015 - 06:26:34 PM »
What model number are those?
1 7/8" or 2" pipes?
They look diferent from their website
Those are nice.
Offline dfrazz
« Reply #9 on: May 06, 2015 - 06:53:52 PM »
1 7/8" or 2" pipes?
Those are nice.
Thanks, these are on a small block 408 stroker and I know you are looking for a BB which is why they may look different.  These are 1 3/4" step headers with 3" collectors polished ceramic coated with a thermal barrier (# TTi 340BE-C5).  I bought the whole 3" h-pipe set up from TTI (#XE30HW-CH).
Offline Rickster
« Reply #10 on: May 07, 2015 - 12:28:00 AM »
Went with Doug's on my 440. Matched up well with the Magnaflow 2.5" x-pipe exhaust. Only issue I had was the copper exhaust gasket I first tried didn't seal well. Used the thick gaskets made by Remflex and they worked perfectly.
Offline 440 SixPack
« Reply #11 on: May 07, 2015 - 08:27:37 AM »
I have also the Magnaflow exhaust system and how do you install them? Do I pull the engine up?
Offline Rickster
« Reply #12 on: May 07, 2015 - 10:46:29 PM »
To answer your question about installation of headers - mine were loosely attached to engine when the engine was mounted on the k-member outside the car. Then engine/transmission/k-member was bolted to car as a unit. If you already have engine installed (which I assume you do), maybe someone else here can give you some advice as I have only done it with engine out of vehicle.
It is a tight fit with not a lot of clearance between right header and right shock tower, but it does fit.
« Reply #13 on: May 08, 2015 - 08:20:28 PM »
I bought Hedman Elite ceramic headers for less than half the cost of TTI. Fit perfectly with no problems. HOWEVER, Brads70 has the exact same headers and did have problems. Are the cars that different, or is Hedman inconsistant in the bends? I don't know.
To me, for the price of TTI, almost a grand, a mechanic should be included to install them.
Offline dsburch
  • Twice, slowly.
« Reply #14 on: May 17, 2015 - 12:22:49 PM »
I went with Dougs on a 383 in a Challenger, and have found them to be very good.  I used copper gaskets, and tightened them again after the first run and about 30 minutes of cool-down, as instructed.  I don't drive the car a lot, but I've checked the bolts occasionally and they have never needed anything else once hooked up properly.  No leaks, no cracks, no pinging noises. Coating is holding up very well after 6 years and about 8k miles.
Several good products out there.  The makers vary the tube routing so look carefully, see if you like the routing, and check into clearances for things like mini-starter, tight-ratio arms and boxes, etc.
« Last Edit: May 17, 2015 - 12:27:54 PM by dsburch »
