Author Topic: Powermaster 140v Alternator on SB  (Read 803 times)
Offline YO7_A66
« on: May 08, 2015 - 06:34:36 AM »
 Has anyone installed the Powermaster #8-47529/8-57529 140 alternator in their sb?
http://www.powermastermotorsports.com/mopar_high_amp.html
Did you have to make any mounting bracket changes?
What did you do with the two existing field wires?
Any pictures of the install?
Any issues with the 1-wire setup on your 3-wire system?
What do I do with my extra wires on my positive stud that feed my accessories?
Will a 1-wire unit drain the battery?
 Note: My existing Powermaster #7508 60a/99a no longer charges at idle. I have already made wiring upgrades in the past to run my existing alternator. Since I need a new alternator, I am now I am looking for a little more power at idle and this existing unit appears to be one of the strongest 3-wire on the marker at that time. After talking with Powermaster, the 140a seems to be the next best choice but it is a 1-wire setup. I have never ran a 1-wire before and I have read a lot about them, but I am after opinions on the install.
 Thanks
« Last Edit: May 08, 2015 - 08:32:36 AM by YO7_A66 »
Re: Powermaster 140v Alternator on SB
« Reply #1 on: May 08, 2015 - 09:23:41 AM »
Avoid Powermaster
 a local rebuilder can probably fix your alt for $20
