Author Topic: checking for vacuum leak  (Read 830 times)
« on: May 08, 2015 - 12:10:49 PM »
Does carb clean loosen paint like brake clean does?  I need to check for vacuum leaks but I don't want to use anything that will discolor or loosen the paint.  What about soapy water?  Will that bubble up around a vacuum leak like it does around a tire leak?  Probably not since there would be vacuum instead of outward pressure.  I don't have a cutting torch so oxy/acetylene is out.  I do have a small propane torch if that would work.
Offline roadman5312
Re: checking for vacuum leak
« Reply #1 on: May 08, 2015 - 12:13:47 PM »
most carb cleaners will eat paint
Offline daveh
« Reply #2 on: May 08, 2015 - 01:29:56 PM »
You can also use WD-40.  That won't eat the paint.  Good luck.
Here's some good info also.
http://www.therangerstation.com/Magazine/Summer2003/VacuumLeaks.htm
« Last Edit: May 08, 2015 - 01:31:36 PM by daveh »
Offline jhaag
« Reply #3 on: May 08, 2015 - 10:00:08 PM »
use your small propane tank around suspected leak. idle will pick up if it is sucking in the propane. you have found your leak
love 70 Challengers
« Reply #4 on: May 23, 2015 - 11:30:53 PM »
The problem turned out to be bad gas.  I had stabilizer in the gas but I guess that doesn't do much if the car sits for a long time.  I siphoned out the tank and put new gas in...problem gone.
