Author Topic: What's a good valve spring compressor?  (Read 2294 times)
Offline ChallengerHK
« on: May 09, 2015 - 09:38:50 AM »
Title says it all  :bigsmile:
- Han Solo, Star Wars
Re: What's a good valve spring compressor?
« Reply #1 on: May 09, 2015 - 12:24:41 PM »
Manual or air ?
« Reply #2 on: May 09, 2015 - 12:30:35 PM »
Mancini has a tool that bolts to the rocker shaft pedestals , works on or off the engine , fast & reliable .
http://www.manciniracing.com/en2pivaspto.html this is for small block , they have one for big blocks too .
 This should work well http://www.tooltopia.com/lisle-16750.aspx but could be a problem with double springs
« Last Edit: May 09, 2015 - 12:33:26 PM by Chryco Psycho »
« Reply #3 on: May 09, 2015 - 12:43:03 PM »
Manual for the moment, but I think you've answered my question. Thanks, Neil.
« Reply #4 on: May 09, 2015 - 12:44:38 PM »
« Reply #5 on: May 09, 2015 - 12:50:44 PM »
What are the advantages and disadvantages of the different designs?
« Reply #6 on: May 09, 2015 - 08:06:25 PM »
C clamp type are what most shops use , but they need to be very ridgid as with high spring loads they will twist , the Mancini C clamp looks much more sturdy & should take a lot f spring pressure .
 The ones that bolt on the pedestals are may favorite as they are very sturdy & can be used with the heads on or off the engine  .
 The Lisle one also can be used on or off the engine but may not work with dual springs
« Reply #7 on: May 09, 2015 - 08:54:21 PM »
Cool, thanks again.
« Reply #8 on: May 09, 2015 - 08:57:41 PM »
not as simple as you thought huh !!
« Reply #9 on: May 09, 2015 - 09:02:15 PM »
I didn't think it was that simple, which is why I decided to ask  :bigsmile:
