You looked into the carb when it is idling to make sure there is no gas dribbling into it?
Old gas not only runs badly, but, it can gum up carb passages and necessitate a rebuild.
When you think you have a cylinder that is misfiring, you can disconnect one plug wire at a time and note if the engine runs the same or misses worse. If there is no change, then you have probably found a cylinder that is not firing right as it should run much worse with one plug disconnected.
If the car has been sitting, that is probably a fuel related problem, I would guess, but I would check the clearance in the distributor make sure it is where it should be as well as clean out any dust, etc that may be coating the inside of the cap.
