Author Topic: Bumper Bracket Removal  (Read 1662 times)
Offline glovemeister
« on: May 09, 2015 - 12:47:13 PM »
Curious how everything gets the front ones off? The bolts on each front bracket are just spinning. With the boxed frame rail it is hard to get a wrench in there, but I have tried, in addition to jamming the nut with a pry bar.
I see that everyone removes them, so there has to be something I am missing.
1971 Challenger RT
Offline anlauto
Re: Bumper Bracket Removal
« Reply #1 on: May 09, 2015 - 02:11:35 PM »
You've broken off the welded nuts inside the frame....very hard top deal with now. Do you have a torch ?
« Reply #2 on: May 09, 2015 - 08:25:39 PM »
Must be stronger than superman or the welds sucked because I did it with a eight inch 3/8 ratchet lol
1971 Challenger RT
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: May 10, 2015 - 12:07:32 AM »
The welds sucked!!!
74 'cuda 360/727
Just call me a gearhead!
« Reply #4 on: May 10, 2015 - 02:58:45 AM »
The welds sucked!!!
Haha dang it, was hoping I was that strong. I really wanted to save the hardware, but I figure I will just go ahead and cut it and buy more when I go to reinstall.
1971 Challenger RT
Offline 67vertman
  • Member since 9-23-2005
« Reply #5 on: May 10, 2015 - 02:12:43 PM »
That's about you only option, unless you want to cut a hole in the side of the frame rail so you can get a wrench/ratchet on the spinning bolt.  Then you will have to weld up the whole.
Offline roadman5312
« Reply #6 on: May 10, 2015 - 02:16:28 PM »
You could get some rubber push in plugs like are used on the floor pan, cut the correct size hole for them, then pop them in when your done.
« Reply #7 on: May 11, 2015 - 01:59:15 AM »
Good idea. Will think about doing that when I manage to get these off.
Car must have been a Monday/Friday welded car lol.
1971 Challenger RT
« Reply #8 on: May 11, 2015 - 01:59:44 AM »
Really appreciate all the posts and the help everyone. By the Way.
1971 Challenger RT
