News:
I hear you!! Mothers day for me too. Well fact is the valves are bent. Now we need to move forward. It can be fixed. Order the valves and seals etc and we'll go from there. You have help here!
You will need a new valve job to mate the new valves to the seats.Someone mentioned above...but I would verify cam timing to be certain that is correct.Then double check clearances and push rod length. Something was badly wrong right off the bat.
Do you have adjustable rockers on this engine? Also is this cam a single bolt or Hemi style 3 bolt?
I have a good guy in Red Deer
PM sent is there marks on the pistons where the valves touched ? , it is inside the reliefs in the pistons or are the valves too wide & hit the edge of the reliefs ? , you may need to fly cut the pistons to match the valves .
