Author Topic: AAR Hood  (Read 2204 times)
Offline EMCD
AAR Hood
« on: May 09, 2015 - 08:17:01 PM »
I just pulled the trigger on a YO AAR hood given the 30% coupon for Mother's Day. I'm going to wrap it 3M carbon fiber auto wrap. I'll do the fender tops to make it look like the AAR, but modernized. Any recommendations or things to consider?
Offline anlauto
Re: AAR Hood
« Reply #1 on: May 09, 2015 - 10:54:07 PM »
Proper AAR air cleaner so the hood will function  :2thumbs:
Offline EMCD
Re: AAR Hood
« Reply #2 on: May 09, 2015 - 11:51:22 PM »
Yep, what reproduction 4bl part should I go for? Don't car if it's metal or fiberglass.
Offline CUDA JAS
  • vroooooom!
Re: AAR Hood
« Reply #3 on: May 10, 2015 - 12:06:27 AM »
are you planning hood pins??
74 'cuda 360/727
Just call me a gearhead!
Offline EMCD
Re: AAR Hood
« Reply #4 on: May 10, 2015 - 12:12:33 AM »
I do currently have pins in my rallye hood. I have the AAR hood dales cuda shop trim rings, etc saved for purchase
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: AAR Hood
« Reply #5 on: May 11, 2015 - 10:54:12 AM »
AAR's had a 6 barrel, not 4.  Ben has the proper air cleaner (http://www.shakerhood.com/products.php?id=CudaParts).  Note, the 440 air cleaner base is different and will not function properly with the scoop, and there is just a slight difference in the top but it is not critical unless you are building a 100 pts car. Here is a pic first of the 440 base and then the correct 340 base.
440 base
Correct 340 AAR base
Offline anlauto
Re: AAR Hood
« Reply #6 on: May 11, 2015 - 02:24:12 PM »
The correct 340 base seals to the hood
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: AAR Hood
« Reply #7 on: May 11, 2015 - 03:12:04 PM »
will need the light weight hood springs also. if you don't have them already.
http://www.rosevillemoparts.com/product_info.php/p/hood-spring-aar-cuda-with-glass-fiberglass-hood/products_id/6925
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Re: AAR Hood
« Reply #8 on: May 11, 2015 - 03:17:33 PM »
Hybrid Fiberglass Solutions was making a 4-barrel base and lid.  That's what I want to run on my Dart.  The owner has been MIA lately on the boards so I don't know if he's still making them or not.
Offline EMCD
Re: AAR Hood
« Reply #9 on: May 11, 2015 - 03:39:29 PM »
sweet, thanks for the advice and links. i'm going to stick with the 4Bl, but want the 6 pack look. I was thinking of not even running the springs at all and just use a hood pole or some bent metal stock to hold the hood open. Will my existing rallye pins work with the AAR hood? I imagine they are in the same location.
