Author Topic: Any ideas on these 4 holes?  (Read 816 times)
Offline flagcraig
« on: May 11, 2015 - 01:56:39 PM »
72 Challenger.  Does anyone know what the four holes are for in front of hood latch mechanism?  Please see pic.
Thanks.
Re: Any ideas on these 4 holes?
« Reply #1 on: May 11, 2015 - 01:59:55 PM »
Hood release....
« Last Edit: May 11, 2015 - 02:01:36 PM by burdar »
Offline anlauto
« Reply #2 on: May 11, 2015 - 02:11:20 PM »
...when you don't have an inside hood release like it appears that you do. :2cents:
Offline flagcraig
« Reply #3 on: May 11, 2015 - 04:31:42 PM »
I do have a factory hood release inside the car.  Does this mean this car did not come with the outside hood release?
Down to limited number of parts on restore and can't locate this.
Thanks.
« Reply #4 on: May 11, 2015 - 04:38:13 PM »
I assume the inside hood release cable attaches right to the hood latch.  If that's the case, then you wouldn't need the standard release lever.  If the header panel is original to the car, you should be able to see if a bolt has ever been in those holes.  Probably not...
Offline flagcraig
« Reply #5 on: May 11, 2015 - 04:52:17 PM »
Sounds good.  Thanks.
Offline anlauto
« Reply #6 on: May 11, 2015 - 05:19:10 PM »
One or the other, not both :2thumbs:
