Author Topic: Anybody have a blown-up drawing of a driver door lock assembly?  (Read 1372 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
My driver door lock is on the fritz... i put the key in and it spins in circles.   I need to figure out how to remove it and rebuild it.
I assume I pull the door panel off and then unscrew a bracket from the interior of the door but at that point.... the inside of the lock is a basic tumbler setup?
Want one?  Got one! ... finally
Offline Rich G
Re: Anybody have a blown-up drawing of a driver door lock assembly?
« Reply #1 on: May 12, 2015 - 07:20:25 PM »
Once you take the door panel off you should see 2 rods on the handle. one for the handle and one for the key cylinder. Plastic clip probably fell off. One nut holds the handle to the door. Take handle out if you need to replace the cylinder
Offline anlauto
« Reply #2 on: May 12, 2015 - 08:02:33 PM »
If the key can turn around 360*, the lock cylinder itself is fubar :2cents:
Offline ShelbyDogg
« Reply #3 on: May 24, 2015 - 10:22:34 AM »
Once you get the door handle off, you'll see that the lock cylinder is held in from behind with screws. Get a new one (or old one) and have a good locksmith key it for your key.
A GOOD locksmith here has all of the old parts needed to do this and charges me $10 to re-key each one. He has a Chrysler "kit" with pins in it.
A BAD locksmith here once charged me to match a key, but after I looked inside it. He just removed some of the pins and springs.
You can get new matched ignition switches and door locks on Ebay. Sometimes an OLD auto parts store with have a lock set on a shelf and it'll be less than $20.
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: May 24, 2015 - 03:07:13 PM »
I do at home but out of town for a few days!
