Author Topic: Removal of A/C on small block 73 chally  (Read 2240 times)
Offline Mopar_Smith
« on: May 12, 2015 - 09:58:49 PM »
I want to remove all the under the hood AC equipment from my 73 Chally 318. It doesn't work, it clutters the look, it probably robs horsepower, it adds weight. Has anyone done this, is it worth it, and can anyone shed info on what kind of pulley belt system required to do it? :working:
Seeker of Truth, Liberty, and the Finer Things in Life.
Offline 67vertman
  • Member since 9-23-2005
Re: Removal of A/C on small block 73 chally
« Reply #1 on: May 12, 2015 - 10:47:20 PM »
I did it on my car when it was a 318.  Pretty easy to accomplish, minimal weight savings but worth it if you want to clean up the engine bay. For me 70 barracuda, I just need a short belt to the alternator.
Offline AARTA340
« Reply #2 on: May 12, 2015 - 11:06:44 PM »
Save all the parts as you may sell or trade the car later on. :thumbsup:
Offline 7212Mopar
« Reply #3 on: May 13, 2015 - 01:54:57 AM »
You will need a non AC water pump pulley and a set of non AC belts.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline Katfish
  • 70 Challenger
« Reply #4 on: May 13, 2015 - 09:15:15 AM »
Should be about 50lbs with everything engine side removed.
Compressor, condenser, drier, lines......more if you remove the AC box under the dash.
Here's a compare for just going to Sanden compressor.
Offline Mopar_Smith
« Reply #5 on: May 16, 2015 - 12:04:08 AM »
I don't think its that easy. But I would love a finished project picture.
Offline 7212Mopar
« Reply #6 on: May 16, 2015 - 12:47:17 AM »
That was what needed to be done on mine. Sorry no pictures now. The heads are off the engine.
Offline 7212Mopar
« Reply #7 on: May 16, 2015 - 11:33:15 AM »
Sorry forgot you have to change the alternator mounting bracket also.
Offline Mopar_Smith
« Reply #8 on: July 06, 2015 - 09:56:51 PM »
Well I filmed the entire process along with a timing chain replacement, pulleys belts, etc. Video should be up in a week or so.
