Author Topic: can anyone tell me where this rattle might be coming from?  (Read 3892 times)
Offline CudamanTom
Re: can anyone tell me where this rattle might be coming from?
« Reply #15 on: May 15, 2015 - 12:57:52 PM »
Sounds strange to me too.
Maybe some of the spray got to bearings for a temp fix, but never heard of a belt making a rattling noise. Especially a noise like in the video.
Edit: looked at the video again. the belts didn't look loose so I can't see the belts being an issue. The rattle sounds more metallic in nature.
Pretty sure a bearing IMHO.
But I guess if the "rattle" went away, I guess it's good... for now.
« Last Edit: May 15, 2015 - 01:00:45 PM by CudamanTom »
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline 734406pk
  • Andy
« Reply #16 on: May 15, 2015 - 01:22:25 PM »
i would recommend changing the belts if that was the noise. One or both may have a flat spot on it from slipping in the past for example. I don't think it is actually belt "lube" but belt dressing. Its made to soften the rubber belt glazing and has some stick-um compound so the belt will grip better. Its just a temporary fix as it doesn't last very long. Is that what you used to make the rattle go away? I thought is sounded more like your crank pulley bolts were loose etc.
Offline djais1801
« Reply #17 on: May 15, 2015 - 01:36:29 PM »
yes you're correct...belt dressing. I will change the belts over the weekend.
Offline MOPAR FANATIC
« Reply #18 on: May 15, 2015 - 02:45:32 PM »
Fan clutch? Can you wiggle the fan blades at all?
just found this thread,the last 2-3 seconds of the vid clip, watch the fan clutch.looks like it wobbled quite abit or am i seeing things.  :clueless:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline djais1801
« Reply #19 on: May 15, 2015 - 09:29:00 PM »
Well good news/bad news....I'm still an idiot!! The PS pulley flew off on my way to a car show. I pulled up to a light-it flew off-light turned red-I picked it up and the belt and continued to the show.
Driving manual steering w a torn rotator cuff was fun...said no one EVER
Offline 734406pk
  • Andy
« Reply #20 on: May 15, 2015 - 09:40:57 PM »
Well at least You foundi it! Kudos to those that posted "it sounds metallic". Did you recover the ps pulley? Good luck on the fix! :thumbsup:
