...hello dodj
the plates were a little wet... but also when I brake.... i.e just before it comes to a full stop, the AFR is going rich ..as soon as the car is in "level" the AFR goes leaner again.... so I think, that the bowl is full up to the very top.
If I use a EDE Performer carb... the heat saok issue isn´t there. That´s why I think, I will give those floats /levels a try...
I will let you know...what´s the result of this "operation "
Greetings Juergen
