Author Topic: bearing numbers rear axle  (Read 1532 times)
Offline brasil
« on: May 15, 2015 - 05:18:29 PM »
Hello Guys...
I need to replace the rear wheels bearings ( the outer ones )  does someone Know the Numbers of the  bearing / retainer ?  So I can go to my local bearing dealer to buy some good bearings instead of this chinese stuff....  the Numbers will start with  "LM " followed by a number...
Thank you !!
Greetings from Germany
Juergen
Offline 73440
« Last Edit: May 17, 2015 - 02:40:33 PM by 73440 »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline brasil
Re: bearing numbers rear axle
« Reply #2 on: May 17, 2015 - 12:45:38 PM »
thank you !
But the Numbers shown.. BCA 7  are not the ones I am loookin for... I need the  LM  xxxx   Number
Greetings Juergen
Offline mopar jack
« Reply #3 on: May 17, 2015 - 01:32:15 PM »
I found this listing at Rockauto for a 71 barracuda rear axle with 8 3/4- 9 3/4. Timken M 201047. The Mopar part number is 3621992
Offline brasil
« Reply #4 on: May 17, 2015 - 02:02:43 PM »
Hello Mopar Jack
Thank you for the number...  the number is for the  wheel bearing cone only.   DO you have the number for the second part ( the race ) ?
Greetings Juergen
« Reply #5 on: May 17, 2015 - 02:22:53 PM »
Dr. Diff shows some LM###s
http://www.doctordiff.com/8-3-4-carrier-bearings-and-races-pair.html
Your choice of quality Koyo carrier bearings for either late or early model 8 3/4" third members.
Kit includes
    2 carrier bearings (25590 or LM104949)
    2 carrier races (25520 or LM104912)
"Powr-lok" (clutch-type) sure-grip or pre 1969 open differentials use 1.8" inside diameter carrier bearings.  Spools, Auburn cone sure-grip, Eaton True-Trac, Detroit Locker or post 1968 open differentials use 2" inside diameter carrier bearings.
Offline 73440
« Reply #6 on: May 17, 2015 - 02:44:18 PM »
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline mopar jack
« Reply #7 on: May 17, 2015 - 04:50:51 PM »
If you order Timken Set7, you will get the bearing, race and the retainer that holds it on.
Offline mopar jack
« Reply #8 on: May 17, 2015 - 10:33:59 PM »
The cup or race as we call it is m201011
Offline brasil
« Reply #9 on: May 18, 2015 - 03:45:53 AM »
@ 73340  the numbers you postet are for the DIFF .. but I need the outer wheel bearings... looks like the call themselfs  SET 7
I hope that my bearing dealer can decode this   into our  LM .....  code
Greetings Juergen
Offline mopar jack
« Reply #10 on: May 18, 2015 - 11:09:54 AM »
You can go to the Timken web site and search their catalog. They have a kit available that includes the cup, cone, retainer, and the steel shim and foam gasket. When you change the bearings you should change the small  seal at the end of the axle. If you can clean your bearings and they look good I would get a grease gun with a small needle attachment and re apply new grease.
Offline brasil
« Reply #11 on: May 18, 2015 - 01:18:11 PM »
found a bearing set..on ebay  Dr.Diff sells the kit for the 8 3/4 axle....
Think I will get two sets / kits from him
Greetings Juergen
