Author Topic: My first Mopar! Craigslist find.  (Read 41919 times)
Offline ed-pv
Re: My first Mopar! Craigslist find.
« Reply #105 on: January 23, 2016 - 11:54:34 AM »
The Camaro spoiler actually looks pretty good!
THANKS!
Offline dave73chally
« Reply #106 on: January 23, 2016 - 05:35:55 PM »
I got a couple of messages regarding the fit of the spoiler.  The only thing I had to do was use my heat gun to slightly form the spoiler to the lower valance of the Challenger.  It was easy to form under a little heat.  The tabs on the spoiler were in good spots to mount.  I found absolute center on the spoiler and then on the valance and started from the center and worked my way out with a few mounting bolts.  When I was done, there were no gaps and it looks pretty much factory.
Yup same with my chebbie spoiler, little heat and mounted it behind the lights. it's off a 68, basically the same but without those 2 center tabs. Here's a pic for anyone who is interested
73 Challenger
Offline ed-pv
« Reply #107 on: January 23, 2016 - 06:47:05 PM »
Nice!
« Reply #108 on: January 23, 2016 - 08:17:05 PM »
you are running hotchkis torsion bars? Any complaints? I've read a lot about low ride height issues
73 Challenger
Offline 70chall440
« Reply #109 on: January 23, 2016 - 11:01:26 PM »
Nice find
welcome.
Current Mopar
Past Mopars
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #110 on: January 23, 2016 - 11:06:39 PM »
How can you have low ride height issues because of a torsion bar?  Just adjust it to the height you want.   :dunno: :clueless:
« Reply #111 on: January 23, 2016 - 11:33:56 PM »
There's a few threads in here about them being indexed differently then stock and they made the front sit very low. Such an issue that hotchkis was calling customers and offering refunds. So I'm guessing with those details, they couldn't be adjusted up enough. I don't if the design has been changed since?
73 Challenger
Offline dfrazz
« Reply #112 on: January 23, 2016 - 11:37:51 PM »
Thanks, and this is good to know.  I ordered the Hotchkis t-bars and should have them on the Cuda within the next couple of weeks, so I will let you know.
Offline TelisSE440
« Reply #113 on: January 24, 2016 - 01:21:31 PM »
There are a lot of problems with different makes. I had ordered Just Suspension 1'' TB and I couldn't install the passenger one, even if I removed the adjuster screw, so I turned the screw almost all the way in, managed to install it and screwed it in just a little more. It was enough for the TB to turn the hex a little ore and then installed it right.
Offline ed-pv
« Reply #114 on: January 24, 2016 - 02:55:28 PM »
I have been running the Hotchkis Torsion bars and I have them set pretty low, but that only because I like the look.  I can raise them about an inch from where they are now if desired.  Mine seem to have enough adjustability.  Not sure, but the the QA1 lower control arms may have made a difference compared to stock.
Offline ShelbyDogg
« Reply #115 on: January 24, 2016 - 04:45:49 PM »
My Challenger, when purchased in '79, had the torsion bars AND the brakes installed on the wrong sides. The drum brake adjusters would loosen when applying in reverse, instead of tightening. The lower control arm adjusters were almost all the way in with the car still sitting too low.
Luckily this wasn't my first Mopar and I fixed it.
 If you have the Torsion bars reversed, the Hex indexing is wrong for both sides and you won't get your proper adjustment no matter where you index your lower control arms, with or without the adjuster in.
If one side is giving problems, like one of the posters said here, the supplier may have shipped 2 bars for the same side.
Easy enough to install both new arms on each side, when the adjusters are all the way out, to see where the lower control arms end up.
Offline whitewatersky
« Reply #116 on: March 08, 2016 - 10:34:26 PM »
while the topic is on sway bars, I'm thinking about how I might be able to solve this issue
the self tapping bolts for the rear sway bars in my T/A are shaking loose
I don't want to put a bolt all the way thru and tighten them up too much in case it pinches into the chassis too much
has anyone done anything different to keep them tight ?
Plum Crazy auto T/A Challenger
Offline ShelbyDogg
« Reply #117 on: March 08, 2016 - 11:32:20 PM »
If you have a welder, zap a couple of spots and grind down. You'll never see it. If you go too small or too far to one side, use a high speed carbide die grinder to center your hole.
« Last Edit: March 09, 2016 - 06:13:59 AM by ShelbyDogg »
Offline ed-pv
« Reply #118 on: March 09, 2016 - 06:50:15 AM »
Maybe drill out the hole and re-tap it.
Offline ShelbyDogg
« Reply #119 on: March 09, 2016 - 08:59:35 AM »
These are a self tapping type bolt, right into the side of the longitudinal. The hole in the sway bar mount limits the mods that he can make. Any welding would be hidden under the bracket that is being bolted down.
