Spectra Fuel Tank W/ Pump
Author Topic: Spectra Fuel Tank W/ Pump  (Read 11325 times)
Offline 3D
Re: Spectra Fuel Tank W/ Pump
« Reply #15 on: July 17, 2015 - 11:33:55 AM »
Tanks inc & Ebay
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #16 on: July 19, 2015 - 01:38:01 PM »
I was thinking of using that set-up on my next restomod, but the quality of the pump is pretty unknown :dunno:
Nice price, The cost of a decent pump is around $150 and up, which begs the question what kinda pump it has?Could be a good price for a tank if it has baffling in it.. :bigsmile:
Offline tman
« Reply #17 on: July 19, 2015 - 01:50:21 PM »
Here is description from Tanksinc.  They say it has internal baffling
•1970-74 Plymouth Barracuda / Cuda EFI Fuel Tank
•Fuel Injection Ready!
•Uses our GPA series fuel pumps, available in 5 sizes.
•Uses aftermarket 5-bolt senders.  Multiple Ohm ranges available to work with factory or aftermarket gauges.
•EFI style internal baffling.  Extra Large 4.3 liter internal fuel tray to prevent fuel pump starvation.
•Perfect for your Pro-Touring, Autocross or Road Racing Ride
•Fuel pump and sender are recessed in the tank for easy installation with no modification needed to your car.
•Looks like an OE tank when installed.
•Coated galvanized steel then Powder Coated Silver.
•19 Gallon Capacity
•Size is: 26-1/4" x 23" x 11"
Offline MrForce
« Reply #18 on: August 18, 2015 - 04:53:54 PM »
Tank arrived from Amazon. It looks good, complete with intank pump, sender, and tray/baffle
Offline Katfish
  • 70 Challenger
« Reply #19 on: August 18, 2015 - 07:12:01 PM »
Nice, any way to get a pic inside to see the baffling?
Offline ShelbyDogg
« Reply #20 on: August 18, 2015 - 07:48:04 PM »
That is nice. I might have to get one. Or 3!
Offline shawge
  • Zoiks!!
« Reply #21 on: August 19, 2015 - 01:12:37 AM »
Looks real good!
- Jerry
Offline GreenFish
« Reply #22 on: August 21, 2015 - 11:19:38 AM »
Tanks Inc Uses Walboro pumps which seem to be pretty nice from what i've heard.
Offline ragtopdodge
« Reply #23 on: August 21, 2015 - 03:19:03 PM »
WOW, awesome stuff!  About time one doesn't have to fork over $1000 for a tank for e-bodies for EFI!
Walbro pumps are good.  Have one in my G35 supercharged coupe.  WOrks good, but DID crap out, but was only $90 to replace it.
So I'm confused...is the Tanksinc tank the same as the SPectra tank?  The Tanksinc tank looks like it has the pump mounting from the top:
BTW, what pump did you order with the tank?
« Last Edit: August 21, 2015 - 03:27:52 PM by ragtopchally »
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline GreenFish
« Reply #24 on: August 23, 2015 - 12:22:20 PM »
Pretty sure Tanks Inc and Spectra are different tanks. Yes Tanks inc has the holes for the pump and sending unit on top. At least thats what it looks like from the pics ive seen
Offline shawge
  • Zoiks!!
« Reply #25 on: August 23, 2015 - 01:06:53 PM »
What GreenFish said - they are different.
TanksInc uses a top mount pump and sender (not sure of original sender hole is plugged?), the Spectra tanks use the original sender hole for the pump and sender.
TanksInc looks to use a bathtub style pan for the baffling, not sure what Spectra has.
- Jerry
Offline crash340
« Reply #26 on: August 23, 2015 - 03:21:08 PM »
Will the Spectra pump/sender unit fit a regular spectra tank, as in is it able to be acquired by itself, I know the regular tank is not baffled but, its an option?
Greg
73 Cuda
Brisbane, Australia
Offline ShelbyDogg
« Reply #27 on: August 30, 2015 - 03:33:42 AM »
Looks like Holley invented this HydraMat material that will no longer need a sump or baffles. Also folds up to fit inside small holes before unfolding.
https://www.youtube.com/watch?v=w0yTNvA50oA&feature=player_embedded
Offline shawge
  • Zoiks!!
« Reply #28 on: August 30, 2015 - 06:00:49 PM »
Last I looked, the Holley HydaMat was very :money:  :dunno:
- Jerry
Offline ShelbyDogg
« Reply #29 on: August 30, 2015 - 10:45:05 PM »
Hmmm, Didn't look at the price. That would change the whole decision on what to buy.  Cool stuff though.
