Author Topic: aftermarket steering comlumns?  (Read 687 times)
Offline aris_unlimited
  • Project in full swing
« on: May 16, 2015 - 07:50:09 AM »
Not sure if this should go here but the reason I am looking for an aftermarket steering column is because I want to do a manual trans swap. And my current setup is a steering column shift auto. I don't like the idea of leaving the stock steering column there as it has the gear indicator on it.
Any thoughts?
« Last Edit: May 16, 2015 - 09:33:36 AM by aris_unlimited »
Cuda is gone :(
74 satellite, daily driver/project now
Offline MrForce
Re: aftermarket steering comlumns?
« Reply #1 on: May 16, 2015 - 08:33:32 AM »
Ididit makes a nice column but they are pricey at around $900. Why not a used OEM column for a from a floor shift car?
« Reply #2 on: May 16, 2015 - 09:35:08 AM »
Haven't really been able to find an old floor shift column...
Cuda is gone :(
Offline 1 Wild R/T
« Reply #3 on: May 17, 2015 - 11:46:20 AM »
FWIW I despise having a GM key in a Mopar... Then theres the scabbed together wiring for the turn signals & Ignition.... There are plenty of original floor shift columns around & really all you need is the one collar that blanks out the shifter.... Keep looking... :2cents:   What car is this for, maybe someone can point you in the right direction...
Edit
If this is for your 74 this is probably what you need....
http://www.ebay.com/itm/Mopar-Steering-Column-1973-B-Body-4-Speed-Charger-Satellite-Console-Floor-Shift-/201321651972?hash=item2edfb49f04&vxp=mtr
Though he is pretty proud of it & I'm sure I could find one for less... But still his is less than an aftermarket column & drops in....
Maybe this guy...
http://www.forbbodiesonly.com/moparforum/showthread.php?58886-Parting-73-Satellite
This is older but might be worth a shot..
http://www.forbbodiesonly.com/moparforum/showthread.php?55200-Parting-Out-1973-Dodge-Charger-SE
Or this appears current
http://cookeville.craigslist.org/pts/5001406274.html
« Last Edit: May 17, 2015 - 03:55:16 PM by 1 Wild R/T »
