Author Topic: Snake Skin Green Challenger Restoration  (Read 65868 times)
Offline anlauto
Re: Snake Skin Green Challenger Restoration
« Reply #15 on: May 25, 2015 - 12:58:35 PM »
Hi Anlauto, i like to take them off and clean them up. Then it's easier for me to paint them off the car, then re-install them afterward. Just my prefence is all. Some people keep them on and that's  fine by me to.
Well you're insured of good coverage that way :thumbsup:
Offline Finoke
« Reply #16 on: May 25, 2015 - 01:01:34 PM »
One of my favorite colors, looking good!
Offline magoo426
« Reply #17 on: June 01, 2015 - 08:47:30 PM »
Finally painted the front bulkhead and tail panel with the blackout treatment.  I used a Hot Rod satin black from the local paint shop.  For some reason this was a little harder to shoot.  I was having a little bit of a problem dialing in the paint gun.  Overall it turned ok I think.  I'll give it another day before I remove the tape and paper to look it over a little more.
Offline Rich G
« Reply #18 on: June 03, 2015 - 08:35:03 AM »
Looks great. What made you choose single stage paint over base/clear? I'm working on my next car and trying to decide which way to go on this paint job.
Offline anlauto
« Reply #19 on: June 03, 2015 - 10:03:29 AM »
I know you're not doing an "OE Restoration", but the black-out up front should be done with the fenders on...now you'll have to black-out the fenders too :2cents:
Offline magoo426
« Reply #20 on: June 03, 2015 - 10:21:21 PM »
Hi Rich G.  Thanks for the compliment.  I chose single stage for me because it's easier for me.  With single stage I don't have to wet sand or buff out the hard to reach / odd angles.  For the exterior sheet metal I will use base/clear because I can wet sand and buff that out pretty easy.  Some people like to use all base/clear and that's cool to.  Whatever gets the job done is all that counts.  This is just my method to the madness.
anlauto, yes you are correct.  This not an "OE" restoration, it is far from it.  It technically is a 1972, but I liked how the 70s look and I had to replace the quarter panels and fenders anyways.  So I thought, might as well make it what I wanted and do a full 70 clone.  I've owned the car since I was a junior in high school, so it's been about 20 years now.  I paint the underside of the fenders and quarter panels black as well.  The backside of the top of the fender that meets with the hood I will paint green since you can see that while sitting inside the car.  Also the back side of the fender near the door will get some green painted on it as well.  I'll break the line between black and green somewhere on the fender that is not seen.
Offline magoo426
« Reply #21 on: June 04, 2015 - 09:00:25 PM »
Here are some photos with the tail lights installed.  Just wanted to see how they looked compared to the blackout on the tail panel.
Offline magoo426
« Reply #22 on: June 14, 2015 - 09:20:56 PM »
Finally painted the back side of the hood and doors.  Progress is slow, but sure.
Offline djw383
« Reply #23 on: June 14, 2015 - 09:39:21 PM »
Mine was not OE either and I painted the black with the car apart, was looking for distinct lines and not overspray. However, if I was doing Concourse then OE would be it....
Sent from my HTC6525LVW using Tapatalk
Offline crocha617
« Reply #24 on: June 15, 2015 - 08:11:37 AM »
This is the one my friend just finished to give you some inspiration.
Offline magoo426
« Reply #25 on: June 15, 2015 - 08:18:39 PM »
Hi crocha617.  Your friend's challenger looks good.  I'll be doing the flat black decal on the hood as well. I'll be putting a black vinyl top on with 71 R/T side stripes, along with the T/A flat black spoiler.  So seeing that picture helps me feel better about my color combo.
Thanks for the photo!
Offline crocha617
« Reply #26 on: June 15, 2015 - 10:08:42 PM »
No problem. I actually like it a lot more then I thought I would. It came out very nice.
Offline twalker
« Reply #27 on: June 15, 2015 - 10:12:24 PM »
Lookin good magoo!!
Offline magoo426
« Reply #28 on: June 22, 2015 - 08:50:14 PM »
Evening everyone.
I was able to finish up the rear valence, and the back sides of the fenders with green and black paint.
Getting closer to painting the body, slow but sure.
Offline anlauto
« Reply #29 on: June 22, 2015 - 09:19:13 PM »
I have to admit, this is the most interesting way to paint a car....can't wait to see the finished project :thumbsup:
