Author Topic: When changing parts, when to get an allignment?  (Read 582 times)
Offline GreenFish
« on: May 18, 2015 - 09:26:31 AM »
So due to a failure of an upper control arm and ball joint I am getting tubular UCAs.  Understanding Ill have to get an alignment when complete due to the change in caster/camber. I also plan to do other parts in the future. I like the QA1 stuff (LCAs, K-member, ect)
My question is which parts require an alignment when replacing/upgrading? I'm trying to figure out which parts make sense to do at once to avoid doing an alignment multiple times.
Thoughts? Advice?
thanks
Offline anlauto
Re: When changing parts, when to get an allignment?
« Reply #1 on: May 18, 2015 - 09:29:46 AM »
All front end alignment adjustments are made with the upper control arm camber bolts and the inner/outer tie rods :2cents:
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: May 18, 2015 - 09:49:06 AM »
I would have the alignment checked anytime I changed the Upper or lower control arms, inner and/or outer tie rod ends, ball joints, and/or front struts. Our alignment machine shows differences of 100th of a degree and the specs are mostly shown in 10th's of a degree. It is easy to change something a 10th of a degree and get it out of spec.    :2cents:
Ken  --  In Georgia
« Reply #3 on: May 18, 2015 - 09:53:33 AM »
Pretty much every time except for replacing steering box, pitman or idler arms. If you are precise in your measurements, you can replace tie rod ends and re-set in your driveway.
Offline GreenFish
« Reply #4 on: May 18, 2015 - 09:57:54 AM »
Thanks guys, I may or may not be looking for an excuse to buy more parts   :burnout:
