Different brass floats ?
Author Topic: Different brass floats ?  (Read 2071 times)
Offline brasil
« on: May 19, 2015 - 07:41:25 AM »
Does someone know...why these Brass floats are different in style ?  Both should match the TQ Carb...but the Newer one looks strange
the "Hump" is on the other side...  (  downside...   UP   ! )...
Did someone use those aftermarket floats..? and where did you meassure the float high ? and what is the correct one for the aftermarket floats ??
Thank you for your help
Greetings Juergen
P.S  the upper one is the OEM brass floet    and the lower one is the newer one ( aftermarket )
« Last Edit: May 19, 2015 - 07:47:17 AM by brasil »
Re: Different brass floats ?
« Reply #1 on: May 19, 2015 - 09:03:17 AM »
Offline brasil
« Reply #2 on: May 19, 2015 - 03:35:43 PM »
Thank you  BULLIT !
can you tell me the hight too.. ?  I can´t read it on your "tool" ...which is by the way a cool instrument !
Greetings Juergen
Offline cudabob496
2011 Kawasaki Z1000
Offline brasil
« Reply #4 on: May 19, 2015 - 03:57:09 PM »
...hmm  29 /32 is too high...  I think .   I sat my "plastic" floats to  1"....  because of the hard starting when the engine is  "warm"...  seems to work better.
I want to use the "aftermarket" brass floats..  with the step in front...  because I think brass works better than plastic
Greetings Juergen
« Reply #5 on: May 19, 2015 - 04:08:54 PM »
The little tool was part of a rebuild kit, I always used the measurement specific to the particular carb I'm working with.
Offline cudabob496
2011 Kawasaki Z1000
Offline brasil
« Reply #7 on: May 20, 2015 - 03:13:05 AM »
Thanky you guys..
so I will set my brass floats to  1"...  this should be a good value
Greetings Juergen
Offline brasil
« Reply #8 on: May 22, 2015 - 03:18:25 AM »
...@ Bullitt
can you do me a favor ?  Would it be possible, that you measure the float hight ( i.e the numbers from your  TOOL )
I run through the www   up and down...but I didn´t found some matching numbers. The problem is, that the OEM brass floats are different in style ..to the Aftermarket brass floats..
Thank you in advance
Greetings Juergen
« Reply #9 on: May 22, 2015 - 10:20:12 AM »
Tool has two float measurements.. 1" & 29/32" .. I had marked to use the 29/32" on this model.
Offline brasil
« Reply #10 on: May 22, 2015 - 05:39:07 PM »
THANK YOU  Bullitt
now I can start to install my brass floats....
Greetings Juergen
