Author Topic: offset sway bar links E body to B body diff  (Read 613 times)
Offline crash340
« on: May 20, 2015 - 04:04:08 AM »
I just spent the last couple of days fitting the B Body diff to my 73 Cuda, so now with no body mods, I have 15x10 (5 1/2 bs) rims with 295's on the rear all good :2thumbs:. interestingly though, looks like I need about 3* pinion wedge under the spring pads!!!! my tailshaft weight is now hitting my X pipe and with the old E body housing I could jack up the body with the diff hanging and undo the rear uni, now I have to jack up the diff several inches to even come close to getting the uni in the yoke!!
anyway, nothing huge.
I was talking to Brad 70 about offset swaybar links to use the factory E body sway bar on a B body spring reloaction, here are the links I made up with a 1 inch offset. just turned them out of 1/2" solid bar, heated them to shape, should be good!!
Greg
73 Cuda
Brisbane, Australia
Re: offset sway bar links E body to B body diff
« Reply #1 on: May 20, 2015 - 09:24:28 AM »
That's cool!  Another member here modified the spring brackets to get them to fit.  I've also heard of people bending the sway bar to make them fit.  I like your solution the best.  Good job!
