Author Topic: Cars running too cool?  (Read 4723 times)
Offline 4Cruizn
  • HEMI FISH
Re: Cars running too cool?
« Reply #15 on: May 28, 2015 - 11:18:55 PM »
My car typically runs 160* to 180* as I sit in traffic and while driving down the road . . . is that bad?
Offline cudabob496
« Reply #16 on: May 28, 2015 - 11:32:23 PM »
I would want a car to run at least 180 with iron heads, and 190 with alum heads!
will get a more efficient burn.
2011 Kawasaki Z1000
Offline 4Cruizn
  • HEMI FISH
« Reply #17 on: May 29, 2015 - 12:04:36 AM »
And I do have aluminum heads . . . so why?  I typically thought the cooler the better?
Offline Strawdawg
    • Vortex Buicks
« Reply #18 on: May 29, 2015 - 02:45:09 AM »
160-180 normally makes the most power on the dyno
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: May 29, 2015 - 02:09:33 PM »
Fuel atomizes the best normally with a 180 degree thermostat which will put you around 190-210 degrees. I doubt you are losing a ton by running cool and I would bet most folks would be envious of your cool running motor. Of course this can vary by motor.
Fighting the other problem is always a huge pain.
B
